| Looked for hours on the net, with no success. Even the 7905 data sheet is useless to me. I nead to make a +-5volt supply. (5volts positive and 5 volts negative). I know how to use a positive volts regulator. You feed it's input with a voltage of about 3 volts higher. But what about the -5 volt regulator.? Does the input of the -5 volt regulator have to be -8volts, or -2volts or 5volts or 8volts, or can it be all? Ideally, I would like to power these two regulators from a single 9volt source/battery. Thanks | |
| The easyest way wod be to center tap the 9V batery to get +4,5V and -4,5V. The other option wod be an switch mode power suply runing on that batery.
| You can't center tap a single battery, but you could use that technique on two batteries. Brian | |
| Back to the old question- what do you want to do? Can't answer without a context. We don't know how much current you need or other critical details. Many times people asking that sort of questions may not even need negative voltage.
| | (permalink) | ||
__________________ L.Chung | |||
| You fogot to mentchon the coil in the 555 timer oscilator.Since it feeds it the negative kickback of the coil that is made becose of the sqare wave. But this method produces a lot of electrical noise.
The op-amp is an TL072 JFET OP-AMP. recommended by Nigel. The project is Automotive, so, primary supply is 12Volts DC. | ||
| Thats why i use norton op amps that dont need an dual suply.But then agen there output cant go negative whithout an dual suply. do you need an negative output?
I book I have talks about a 7660 voltage converter. It converts any positive voltage from 0 to 12 volts to a negative0-12volts. I catalog I have ,also talks about dc-dc charge pumps, with that chip. Maybe I'm onto somthing purpose made for op-amps? thanks. | ||
| Most prpole use 2 baterys to do it.
| | (permalink) | ||
| http://sound.westhost.com/project69.htm This and your regulators should work ok, or; http://sound.westhost.com/project95.htm
__________________ Angry!? I'm absolutely electrolytic! Will have to make do with myspace now I guess... | |
| Nigel Said Quote:
WinPicProg PIC Tutorial ERROR The requested URL's could not be retrieved so, I gave up trying. Just now I went to your other link (forgot you had two websites). "http://www.lpilsley.uklinux.net/picprog" <this site works, and yes I found the 7660 chip. Thanks for getting on my back about it. | ||
