| Hey I have a Minolta laser Printer (magicolor 2400W). It works on AC 110-127V (i=11A) (Brought from USA). I have 220V. What should I change in it's power supply to make it work in my contry? Or will be better to buy a transformer from 220V to 110V (but it too expansive)? thanks a head... | |
| Too many work... The big problem: heater lamp for 120V and 1500W! You can only change, and expensive. The main psu most of case built only for 120V, modification not impossible: sometimes only a jumper setting. Conclusion: the "expensive" trafo is the cheapest and safe solution."Autotransformer" is a best, isolation no needed. | |
| Yes you use an auto-transformer, they are relatively cheap as they only have a single tapped winding. As Sebi mentioned, they don't provide isolation, but isolation isn't required. | |
| Hey Zener, I had the reverse problem 2 years ago. I lived a while in France, and when I got back to Canada, I had several gadgets, peripherals and appliances running on 220V that I needed to power off 110V. A Toshiba laptop plug I bought in Europe had a 2 part power cord, one that housed the 110/220 AC/DC transformer that plugged directly in the laptop power socket, and one with the country-specific wall plug. I just had to replace the latter. Make sure your Minolta printer isn't already able to handle the 220V. Also check Minolta's website, they might offer a cheap accesory for travelers that will do it. For the other 220V-only stuff, I bought off-the shelf step-up/down transformers that can do 110-120-220-240V in any direction and adapt to any wall plug in the world. I paid between $20 and $25US each for 100W & 200W models, along with a little $5 50W transformer that could power my little 25W soldering iron. Well worth the $ in my opinion. Check the PowerBright link above, they have 1500W to 3000W options... Might not be worth it for you to buy in the US, but maybe you can find a distributor in your country?
__________________ Time is nature\'s way of keeping everything from happening at once. http://membres.lycos.fr/jrainville/ | |
