Old 4th September 2005, 10:32 AM   #1
Default Sharp Distance sensor
Hi All
I have been looking in the datasheet for the Sharp distance sensor GP2Y0D340K, but couldn't figure out, how the output is been converted. Does it generate an output in the same time period as the distance to the object, or what?
Electronics4you
______________________________________
Electronics4you is offline
Old 4th September 2005, 01:01 PM   #2
could you post the data here please? or the addres
Need Help?
Press F1
If that doesn\'t help you, ask me... I might know better.
bloody-orc is offline
Old 4th September 2005, 01:30 PM   #3
Yes of course
http://www.active-robots.com/product...gp2y0d340k.pdf
Old 4th September 2005, 05:15 PM   #4
it looks like time between two rising edges is proportional to the distance.
the scale is 0.1ms/cm.
panic mode is offline
Old 4th September 2005, 07:27 PM   #5
as this gives you a low pulse, you could mesure the distance and read the pulse with the sensor and display the result on a LCD or om computer. i think that it is so tha 1 cm = 1ms of low pulse, but i'm not 90% shure.
Need Help?
Press F1
Old 4th September 2005, 07:44 PM   #6
i don't think so, if it was 1ms=1cm, it would require 60ms output for 60cm distance.
Old 4th September 2005, 10:57 PM   #7
Default Re: Sharp Distance sensor
Originally Posted by Electronics4you
Hi All
Hi Electronics4you,
Looking through the datasheet, I think this chip is a fixed distance indicator. If you are 'far' away from the reflective surface, the Vo is '1'. When you are 40 +/-5cm and closer from the surface the Vo output is '0'. At least this is how I read the info in the datasheet.
TOK
Gorgon is offline
Old 5th September 2005, 01:32 AM   #8
If you check all the solder joints with a voltmeter you will find one that varies voltage proportional to distance. I believe it was 2 to 4 volts or so.
jkmadsci is offline
Old 5th September 2005, 09:45 AM   #9
As I remember, there are TWO versions of the Sharp distance sensors, one provides a varying DC voltage output, which represents the distance measured. The other type just provides a switched output at a certain range, so can't actually measure varying distances - so you need to make sure you get the one you need!.
Old 5th September 2005, 02:23 PM   #10
Sharp makes lots of parts. Distance sensors from Sharp i remember dealing with ware GP2D1x series. They came in different versions too (fixed output, analog output and serial output). Ones i have are with analog output...
distance, sensor, sharp
