| Looking at the datasheet with forward voltage of 1v there should be around 170ma On my test circuit I have 10vdc supply limited to 200ma, series resistor of 470 ohms and then the 1n4148 diode. My question is why am I only measuring 20mA ? I have a voltage of .95 across the diode which suggests I should be getting at least 100ma. Thanks Graham | |
| Small calculation: (10V {psu voltage} - 0.95V {diode Vf} ) / 470 ohms = 0.0193A = 19.3mA. Your series resistor is too high a resistance to allow 100mA from a 10V supply. Try reducing it to 82 ohms or so. | |
| Maybe you expect the diode to generate 100mA? Then try it without your 10V supply. :lol: :lol:
| I think you may be looking at it in a wrong way. The forward voltage drop is specified with a average current. This voltage drop can vary with temperature. In fact the older version of the 1N4148 the 1N914 has been used as a temperature sensor on occasion by monitoring the forward voltage with a specified current flowing thru it. I also remember seeing a circuit or two that used the forward voltage of this type of diode as a voltage reference source.
__________________ The great thing about electronics is unlimited ways to do the job. The only limit is one\'s imagination. I generally think my way is best. Show me a different way. I have an open mind. | |
