| For all of you who just adore (and only adore) Windows XP, start laughing at me, because I am going old school style. What I want to do is be able to actually read any byte I want from a floppy disk. I am using a standard 3 1/2 inch floppy disk drive to help me out. The problem is that everything I have done so far has lead to failure. I even tried connecting the output pins to the LED's and the only output pin that seems to work is the write-protect detection pin. When I plug the floppy drive into the computer, it works normally. I have searched several websites, and there is not one single website explaining the details on how to manually read a single byte from a floppy disk! Why do I want to do this? Because it is SAFER, and the risks are somewhat lower. I want to eventually take raw data from a floppy disk, (from bit 0 to the end) and program a microcontroller from it. Also, I want to program some bios chips and hopefully get my old bios working again. I just picked up another motherboard, and I am using it now as part of my computer. The only two drawbacks are loss of speed, and no CD-ROM booting.
__________________ -=: The best low-priced components to troubleshoot with are the speaker and the LED :=- | |
| What do you mean by manually read a single byte? Are you looking for software to do that for you, trying to write software on the PC that'll do that, using a uC connected to the drive? Your post is not clear on what you are trying to achieve.. | |
| | (permalink) | ||||
BTW, a poster on my wall (of my first computer system), shows a picture of the floppy disk controller (which I never had, too expensive!), it has 23 IC's on the board!. Quote:
If you do a web search you can find IDE interface details for connecting CD-ROM's to PIC's (and other micro-controllers), but an IDE interface has most of the controller circuitry on the drive, so the external interface components are minimal. There was a long thread on the PICList years ago about trying to use a floppy with a PIC, as far as I know no one managed it? - an obvious snag is the lack of RAM, as you need to store at least a single sector. | |||||
| IF you were in linux I would suggest "dd" and make a copy of the floppy (byte-wise) and then edit that OR just go "vim /dev/fd0" however, since you seem to be a windows user, I suggest http://www.hexworkshop.com/ I used this back in 95days when I had to learn abt harddrives and the VFAT filesystem. I started with floppies and then carried on from that. | |
| As Nigel stated, you cannot read/write just a byte. But only in sectors (for a floppy with VFAT that is 512 bytes) However, with a sector loaded you can then manipulate the byte you want and write that sector back | |
| However, reading your post a bit more.. You want to interface directly with the floppy. IT is possible, just goto a floppy drive manufacturer and they should have the pin-outs as well as access times | |
Next, isnt it much simpler to make a less fancy serial/parallel programmer? | ||
| Yes, reading compactflash or Secure digital cards with a pic (or any µC) is easy... Compactflash is the most easy and doesnt require extra memory (like Nigel said , you need to read 1 sector at a time wich is 512 bytes for CF, but the CF card has a 512byte buffer built in) - it does however require a whole lot of µC pins. SD is a little harder and you need your own 512byte buffer memory (I²C ram would do nicely, or a µC with enough ram to spare), but since it's serial it only requires few pins... And face it, a memory card slot on your project is a lot better looking then ickky disk drive :lol: There's lots of info on the net 'bout CF & SD interfacing. I would also like to add that a memory card is safer then a diskdrive... I haven't had any data failures on a memory card yet, but my pile of defective diskettes is getting larger all the time... | |
| | (permalink) | ||
The only other options I have is to interface my own programmer with a CD-ROM drive, or a hard drive. I prefer using the floppy drive because there are only 34 pins to deal with, and from what I have learned, 1/2 of them are grounded.
__________________ -=: The best low-priced components to troubleshoot with are the speaker and the LED :=- | |||
| You want to design an interface so that you can connect your microcontrollers to a floppy drive for the purposes of programming them??? I really can't understand why anyone would dream of doing such a thing. You're going to need to design your own file system, and write some firmware to support it. Once you've done that you're going to need to write some software which will take the data you've obtained from your floppy drive and program your required microcontroller with it using the required protocol for that particular microcontroller. If you then decide you want to program a different type of microcontroller, you're going to need to re-write part of your software to support it and you're going to need to do this EVERY time you decide that you want to work with something different. Then you're going to need to build a dedicated system which permanently interfaces to the floppy drive, and a suitable output interface for connecting to the desired microcontroller. This interface would also have to be adapted each time you chose a different type of microcontroller to work with. Even assuming you're willing to do all that work, and you're capable of doing it, I still don't see how you're the slightest bit better off. Especially since floppy disks are a highly unreliable way to store information. If you've been damaging parallel ports using parallel programmers, you've been doing something wrong. Hmmm Brian | |
Just use a little common sense, respect what a parallel port is, and don't attempt your usual random connections!. In the same vein, your floppy programmer idea is even more stupid!, there are numerous programmer designs out there, pick one and build it properly!. | ||
| Maybe nigel can cool off abit. We've all done stupid things at various points of our lives. | |
| | (permalink) | ||||||||
__________________ -=: The best low-priced components to troubleshoot with are the speaker and the LED :=- | |||||||||
| | (permalink) | |||||||||
