Yes thanks. I hooked it up to a 9v supply now and the device can now out put 1.6-5v instead of 1.6-3.5v. My problem is getting it to go below 1.6v? I saw in a previos post to use a 10k ohm resistor at the output or something and well it does nothing. Thanks for all your input and you long posts, they are very helpful. Edit: By 1.6-5v (and 1.6-3.5v before I changed the supply from 5v to 9v) I am not altering the input but rather the "clamped" voltage off the potentiometer. Maybe that is my problem and I should put a potentiometer at the input as well and set the clamp to 5v but turn the input down all the way. Last edited by RedCarzRFaster; 10th August 2006 at 04:33 PM. |
Hi again,
How are you testing this? Have you got a pot (voltage divider) connected to the input and the +5v supply (one lug 0v, one 5v, and the wiper as the input), so you can vary the input voltage form 0-5V just by turning it? quote: Maybe that is my problem and I should put a potentiometer at the input as well and set the clamp to 5v but turn the input down all the way. Yep. Although the pot at the input would 'simulate' the output of your sensor. So you set the clamp votlage pot, and slowly turn the input from 0v to 5v, and it 'should' hold the output at a certain threshold. if the input is unconnected, god knows what it will do...probably just pick up noise, so the voltage could be anything. I think that the reason your circuit refuses to put out less than 1.6V is because of the opamp itself. As I said, opamps have an output voltage swing less than the supply voltage, it will never output 0V or Vcc (your power supply voltage), I guess, for your opamp, the lowest outptut with respect to ground is 1.6V. http://hyperphysics.phy-astr.gsu.edu...ic/a741p2.html for a different opamp, but has useful info The LF358 apparently allows the output voltage to be very close to the negative supply (GND in this case) are you using this one? Theoretically, it should allow it to drop below 1v. From that 'DIY FCD' page, he does explain it rather well, and I've been thinking about that circuit, but my analogue knowledge is not what it should be. All it seems to be is a voltage follower (a buffer) with a low pass filter on the input to attenuate noise pickup (but not eliminate), and a comparator. The comparator uses a diode in reverse bias so that the output swtiches from one input, to the other. Ie: from your signal, to your reference, set by the pot. (bit similar to my idea, but simpler, and rather clever If your app (your sensor) is identical to the one in the page mentioned above, then I don't think you need to worry, as the graph he has shows the lowest output of the sensor to be in the order of 2v. Let me know how you get on. Blueteeth.
Inconsistency is the key to flexibility! |
Hi, forgot to add something.
The graph on the page only shows voltages from 2-5V from the sensor, with 'pressure' on the X-axis. However, the circuit doesn't need to do anything (except pass the signal through) until the clamping voltage......which he suggests you set between 3 and 4v. I've just prototyped it, with a TL072, but it'll do. And theres strange behavoir when the input drops below 1.5V The output shoots straight to 4.9V regardless of the clamping voltage. Also, if the clamping voltage is set below 3V, it doesn't clamp.....the output will go straight past it to 3.5V BUT...it still lowers the gain of the opamp somehow....that is, with an input of say 4V and a clamp voltage of 2.6V the output is 3.2V. If it was 'perfect' that would be 2.6V obviously. Now, thats obviously not great clamping, it lets it go past the threshold. However, for the range he stated it needs to operate on, given the sensor signals range (2-4V apparently) and the threshold which should be set between 3 and 4V, it works. Surprisingly well. I'm unsure why it behaves wonderfully in this range, but output it goes 'gaga', probably because of the limit of the opamp unable to output (or even input) voltages within 1.5v of GND or VCC. I don't think the diodes bias of 0.6v has much to do with it though. So, it seems to be absolutely fine for HIS application. Howabout yours? I've been racking my brains for a solution, but other that the ones I came up with in the other topic, I'm stumped for now Blueteeth.
The inputs of a TL072 are Jfets and they don't work and cause the output to suddenly invert when the input voltages get to within about 2.5V from the negative supply.
The inputs of an LM358 work fine down to the negative supply.
Uncle $crooge |
Use an LM393 as an op amp, and it will go almost to zero on the output, because you don't need the diode. The LM393 doesn't have a lot of bandwidth when used this way, but it will still be lots faster than you require.
Hi Ron,
Doesn't the LM393 comparator oscillate when it has negative feedback? Or does the 10nF with the 100 ohms compensate it?
Uncle $crooge |
Out of curiosity and topic... wich sim software are you using?
