Mechie, It's running 0.02% too fast. I'm getting an error of 18 seconds per 24 hours and thats using that 39pf trimmer on that data sheet. Looks like I nead to use more pfs then the 39pf specified. Is it ok to us more? I also did not use a voltage regulator.Does it matter with crystals? i used 4.5Volts (3* 1.5 volts AA batteries) What does 100ppm mean? Thanks | ||
| | (permalink) | ||||
| Nigel asks Quote:
I hooked up the seconds pulse of it to the parallel port. Wrote a program in QBasic to tell me the time when the port receives a low/high input signal. Qbasic's timer command has a resolution of 0.01 second. I'm now getting an error or 0.01 second every 3000 seconds. or an error of 0.28 seconds / 24 hours when compared to my pc clock. I think my pc clock is accurate to within a second per day when updated daily from the internet clocks | ||
| | (permalink) | |||
As your resolution is 0.01 seconds, by definition the accuracy can be no better than + or - 0.01 seconds, and the way the QBASIC timer command works will make it worse than that!. | ||||
| | (permalink) | ||
| Nigel says Quote:
Nigel says Quote:
Next time I will not run Qbasic. will just let it run over night (12 hours) and see visually how many seconds its out. I also have a seven segment thing showing seconds. eg. when it's 10:00:00 pm on my computers clock, I'll turn on the crystals power . After 12 hours, I'll see if the seconds are still syncronizing with the pc clocks second hand. Oh, I'll use a voltage reg too (i forgot to use it today). Thanks | |||
| It is best to test your clock circuit after it has warmed-up. Its frequency will be stable and that's the way you will use it anyway. :lol:
run it under power for a period of time for it to stabalize? | ||
| Temperature.
| Cool, I've been doing that and documenting the temperature of the room. | |
| It's very interesting when you put 4 quartz clocks infront of you and you watch the second hands/display for a few hours One of them, a no-named digital was a second slow only after 40 minutes. Another, a seiko quartz analoge, was a second slow after a few hours. compared to my pc clock. Don't know the battery state of the clocks. Interesting. | |
If you have Teletext in your country?, try comparing it to the Teletext time (ensure you use the same channel every time though). | ||
| Nigel says Quote:
Pitty, I don't have a teletex tv. I agree with what you said about updateing of the internet before taking time readings (which I have been doing). My pc's clock is within 1 second/day compared to internet time servers. | ||
When I had a VCR it set its clock automatically to "teletext?" from a TV station. Then it screwed-up. I e-mailed them and they thanked me for pointing out their problem and it took about 1 month for it to be fixed until it screwed-up again a few months later. On my new digital recorder I just highlight the program on the cable TV's guide channel and push the Record button on my remote. It even knows if my program is delayed or runs into overtime. :lol:
| | (permalink) | ||||
Or is it a digital TV system?, which again must send some kind of start and stop signals to accurately record a program - and obviously relies on these signal being inserted!. | |||||
| [quote="Nigel Goodwin"]It doesn't sound like your TV stations are very reliable?.[quote] The station is an old non-profit American one. Canadian stations are newer and more reliable but don't broadcast the time signal. Quote:
