Hi, I built a LPT programmer for xilinx CPLD as shown in official Xilinx doc. But when i try to program something, using ISE software, the software does not recognice my programmer. I use Windows XP. Maybe is some incompatibility with OS ?? I checked the correct working of IC's and routing... Thank you. | |
| | #2 | |
Yes, I know that, and that's the reason I asked about it. I don't know if the software should work with LPT in XP. It definetly works under windows XP as it is quite new soft, but I asked for if someone has used ISE and Xilinx CPLD and knows. | |
| | #4 | |
well i have used Xilinx ISE but i used it to program an FPGA. the target development board was one of the XESS boards. there was a small loader type of software in which the bit file is just dragged into a small space and the bit stream is given to the development board. have you tried to contact Xilinx on this? they may be able to help you.
__________________ Beginner's Guide to Microcontrollers | |
| | #6 |
Yes, I'm going to try that, just in case
| | #7 |
iMPACT, the software Xilinx uses to program devices, works fine with 2000 and XP. I would check your circuits and software configuration for problems. I use the JTAG programmer that came with my Digilent S3 board. It is parallel port based and works flawlessly with all the ISE webpack features. | |
| cpld, programming, xilinx |
