| Hi guys.I'm trying to write a program which is kind of like a simple Flash memory programmer.I can read the *.BIN file into an array of byte buffer variables.And I can display the content of the BIN file in a text box.But the process is really slow and it even freezes the entire PC.What I did first is assigning each byte the respective value read from the file.Just like the last segment of the code listed down there.This process takes about 3 seconds to open a file with a size of 261KB,and the computer freezes during this period. To display the content I used samilar structure as this: TextName.Text = TextName.Text & ....... and the computer freezes a lot longer before the result comes out. I'm working on hardware most of the time so Visual Basic isn't really familiar to me.I bet I chose the worst way to preview the BIN file. :? Could someone here show me some better ways?Thank you in advance! Regards,Alex '=============== Dim i As Long Dim Lib() As Byte Dim Buf() As String Dim Ptr As Long Dim Lp As Integer '--------------- 'Open file Path.Action = 1 Open Path.FileName For Binary Access Read As #1 '--------------- 'Redefination i = LOF(1) 'FileLen(Path.FileName) ReDim Lib(i) As Byte ReDim Buf(i) As String '--------------- 'Display file information TextName.Text = "File Path: " & Path.FileName & Chr(13) + Chr(10) TextName.Text = TextName.Text & "File Length: " & i & "Bytes" TextName.Text = TextName.Text & " (" & CInt(i / 1024) & "KB)" & Chr(13) + Chr(10) & Chr(13) + Chr(10) '--------------- 'Read file into buffer Ptr = 1 'Attention:Starting index = 1 rather than 0x0 in MC systems. For Ptr = 1 To i Get #1, Ptr, Lib(Ptr) Buf(Ptr) = Hex(CInt(Lib(Ptr))) & "H " If Lib(Ptr) < 16 Then Buf(Ptr) = "0" & Buf(Ptr) End If Next Ptr Close #1 '--------------- | |
| you are killing your computer by reading byte by byte. don't do it. :lol: :lol: read the whole thing into memory and then manipulate it any way you like but for your HDDs sake, avoid reading byte by byte. files on any media (HDD, FDD, ...) are stored in blocks. if your HDD is formated to use 4kb blocks than this whole block is taken even if the file in it is one byte. if the file is larger, it will take multiples of blocks. when your program tries to read or write from file, it sends requests to operating system to read or write. operating system finds right block(s) and read the whole block (or series of blocks) at once. ....even if you only asked for one byte...!!!! if you are reading 260kb file from HDD that uses 4kb blocks, your pc is reading total of 65 blocks. each block is read 4096 times (4kb=4096 byte). it means you are asking your HDD to do same job 4096 times instead of once. since HDD is still just a MECHANICAL device that need to move disks, heads etc., this is major reason why it takes forever... fortunatelly HDDs usually have some cache to help them in such cases but in a windows enviroment there is tons of other things running at the same time and accessing the HDD. although this does reduce stress on the system, it doesn't do miracles... | |
| Sounds scary :shock: Anyway I will need a better idea. I don't knwo how VB handles the file when the open file operation: Open Path.FileName For Binary Access Read As #1 is executed.Does it just designate a pointer to the location of the file on HDD and read each byte for HDD when GET BYTE operation is executed later? What would you suggest that I did other than the current method?Thanks! Regards. | |
| Heres some code that will read your file into a textbox create a new project and form create a button command1 on your form create a textbox text1 on your form add this code and change the filename to your file and path: '""""""""""""""""""""""""""""""""""""""""""""""""" """"""""""""""" Private Sub Command1_Click() Dim filenumber As Integer, length As Long filenumber = FreeFile Dim filename As String filename = "c:\test.txt" Open filename For Input As filenumber length = LOF(filenumber) If length < 32767 Then Text1.Text = Input$(length, filenumber) Else MsgBox "This file is longer than 32Kb" End If Close filenumber End Sub '""""""""""""""""""""""""""""""""""""""""""""""""" """"""""""""""""" it should be much faster Mike | |
| did this work for you? | |
__________________ Time is nature\'s way of keeping everything from happening at once. http://membres.lycos.fr/jrainville/ | ||
| You also have to give other apps runing on your PC some CPU power.So that it dosent freze in case your opening an big file. I forgot how that comand is caled in VB.Dose anybody remember?
| I have been working on some binary files: Code: Private Sub OpenFileDialog1_FileOk(ByVal sender As System.Object, ByVal e As System.ComponentModel.CancelEventArgs) Handles OpenFileDialog1.FileOk
Dim fs As System.IO.FileStream = New System.io.FileStream(OpenFileDialog1.FileName, System.IO.FileMode.Open)
Dim r As System.IO.BinaryReader = New System.IO.BinaryReader(fs)
Dim i, j, k As Integer
Dim working As String
For i = 0 To 15
k = 0
For j = 15 To 0 Step -1
working = DecimalToBinary(r.ReadByte())
working = working.PadLeft(5, "0")
maze(k, i, 1) = working.Substring(Len(working) - 1, 1)
maze(k, i, 2) = working.Substring(Len(working) - 2, 1)
maze(k, i, 3) = working.Substring(Len(working) - 3, 1)
maze(k, i, 4) = working.Substring(Len(working) - 4, 1)
maze(k, i, 5) = 0
maze(k, i, 6) = 0
k = k + 1
Next
Next
r.Close()
Me.Refresh()
End Sub [damn i need to comment my code...] Regards, - Martyn | |
somming like that oh and BTW i am using VS.net 2003 (oh yeah, got it free from uni) | ||
