Old 14th July 2005, 01:44 AM   (permalink)
Default LED
i am currently using a PC1602-F LED
(http://www.insideelectronics.net/projects/clock/pc_1602f.pdf#search='1602F%20)
i am currently using a PC1602-F LED ,i would like to know where do i connect Contrast Adjust (Pin3), Register Select Signal (Pin4) and both Power SUpply for LED B/L, + and - (Pin 15 & 16). Can i manually test if they are working by connectin them to ground and vcc?someone pls help,thanks a lot.
Hihi is offline   Reply With Quote
Old 14th July 2005, 02:25 AM   (permalink)
Default Re
i meant to say LCD, my bad...
Old 14th July 2005, 06:30 AM   (permalink)
I recomend searching a LCD tutorial. it normally shows what must be connected where. The way to test if LCD is working is to connect power to it (pins 1 & 2) and also power thecontrast pin with whatever voltage it needs. The backlight unit is independant and requires 4.2V ~160mA.
Need Help?
Press F1
If that doesn\'t help you, ask me... I might know better.
bloody-orc is offline   Reply With Quote
