+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 22
Thread: How to get my usb-com-pic link working properly
  1. #1
    bloody-orc Newbie
    Join Date
    Aug 2004
    Location
    Estonia
    Posts
    728
    Default How to get my usb-com-pic link working properly
    does anyone know hot to convert usb 2.0 into usb1.1? changing in software would be the best.
    Need Help?
    Press F1
    If that doesn\'t help you, ask me... I might know better.
  2. #2
    Super Moderator Jay.slovak Good Jay.slovak Good Jay.slovak Good
    Join Date
    Jan 2005
    Location
    Slovakia
    Posts
    1,740
    Default Re: how to convert usb 2 into usb 1.1
    Quote Originally Posted by bloody-orc
    What exactly are you trying to do? USB2.0 is backwards compatible with USB1.1 so there is nothing to solve. :wink:
  3. #3
    shamikrudra Newbie
    Join Date
    Jul 2005
    Location
    India
    Posts
    27
    go to bios setup and deseble USB 2 and it is now USB 1.1
  4. #4
    zevon8 Newbie
    Join Date
    Apr 2004
    Location
    Toronto, Canada, eh
    Posts
    928
    I agree with Jay.... what is it you need to do? Downgrading the port doesn't seem to answer the original question?
    If a device is only capable of 1.1, the port will figure this out and behave accordingly. If the connected device cannot communicate it's abilities I am not sure if it would work ( be recognized and initialize ) in the first place.
  5. #5
    bloody-orc Newbie
    Join Date
    Aug 2004
    Location
    Estonia
    Posts
    728
    the problem is that it doesn't figure it out :P it kinda works with usb 2: it understands, that my usb->com port is connected to it.
    i try disabeling usb 2.0
    Need Help?
    Press F1
  6. #6
    checkmate Newbie
    Join Date
    Aug 2003
    Posts
    402
    You have a problem, but you have not described it in enough detail, and there is nothing we can really do but to guess what exactly your problem is.
  7. #7
    bloody-orc Newbie
    Join Date
    Aug 2004
    Location
    Estonia
    Posts
    728
    my problem is, that my usb->serial(COM) converter isn't working. My laptop sees it (it says hadrware working properly) and generates a COM port, but this port is not usable. I'm trying to program my pic(axe) with it and it says hardware not accessible. When i unplug the usb cable from my laptop and stick it in the PC i can download the program in my PIC with no problems. I think my PC is old enaugh to have USB 1.1 not 2.0 but laptop is pretty new.
    Need Help?
    Press F1
  8. #8
    Join Date
    Jan 2005
    Location
    Slovakia
    Posts
    1,740
    I think it's Windows fault, not hardwares. Make sure you are using correct drivers.
  9. #9
    bloody-orc Newbie
    Join Date
    Aug 2004
    Location
    Estonia
    Posts
    728
    windows is same on both of them (xp home SP1) drivers seem to be also the same
    Need Help?
    Press F1
  10. #10
    Join Date
    Jan 2005
    Location
    Slovakia
    Posts
    1,740
    I suppose you should upgrate to SP2, SP1 has many painfull bugs... (Including Firewire and USB)
  11. #11
    panic mode Newbie
    Join Date
    Nov 2003
    Location
    mississauga
    Posts
    950
    i'm not familiar with picaxe but laptops are devices designed to live with limited power and usb ports are often starved (have limited power).
    did you try to connect USB hub that has external power supply?
    If the power is an issue, this should cover for it. some USB devices require use of two USB ports when connected to laptop (like USB<>IDE interfaces etc.).
  12. #12
    bloody-orc Newbie
    Join Date
    Aug 2004
    Location
    Estonia
    Posts
    728
    thanks for the info.
    those USB hubs are darn expencive can't I connect a battery to the wires to increase the power? of cource regulated power suply. Also my laptop is mainly on a cable so it should have the power needed. The picaxe only uses 2,3,5 pins on COM port (Tx,Rx,Gnd). I dont know if those need wery much power or not
    And how big is the % that my thingy might start working after installing SP2? it takes a full day to get that on my computer and i don't have one to spear.
    Need Help?
    Press F1
  13. #13
    Join Date
    Jan 2005
    Location
    Slovakia
    Posts
    1,740
    The chance that SP2 will help you is about 25%, give it a try. SP2 will solve many problems.
  14. #14
    bloody-orc Newbie
    Join Date
    Aug 2004
    Location
    Estonia
    Posts
    728
    and also causes the same amount when using older technologie. Well i'll see if the admin alows to do this on it.
    Need Help?
    Press F1
  15. #15
    Join Date
    Jan 2005
    Location
    Slovakia
    Posts
    1,740
    SP2 has more benefits then problems, you have to try it out!
+ Reply to Thread
Page 1 of 2
1 2 Last
Tags for this Thread
