Old 7th July 2005, 01:52 AM   (permalink)
Default Capacitor voltage rating
Hi all,
anyone know wat will be a save range to chose for a capacitor voltage rating? i want to filter a ripple signal from a 48V output rectifier. the capacitor i use should have what voltage rating? thanks!
cheers!
Skyy
skyymanz is offline   Reply With Quote
Old 7th July 2005, 02:27 AM   (permalink)
I assume by 48V you mean RMS value (i.e. constant DC value)
so the Peak voltage of your signal will be 48*(2^0.5) = 68V
and we normally keep safety margin of 1.5
So you requirment will be 68*1.5 = 102V
So I will recommend you to use a capacitor with atleast 100V rating
The following link might be useful for you
http://www.electronics-tutorials.com...wer-supply.htm
Instruite
http://www.icesociety.org
Ideas that work,
Concepts that sell.
instruite is offline   Reply With Quote
Old 7th July 2005, 03:14 AM   (permalink)
Default Re: Capacitor voltage rating
Originally Posted by skyymanz
Hi all,
cheers!
Skyy
u can use 63 V or for more 100V for safty
but consider the space 100V will be bigger in size
shamikrudra is offline   Reply With Quote
Old 7th July 2005, 03:21 AM   (permalink)
Hi instruite
Thanks for the reply!
Old 7th July 2005, 10:08 PM   (permalink)
personally, I double the applications requirement just incase AC voltage is used. so 48 * 2 = 96. capacitors with higher numbers are much better.
-=: The best low-priced components to troubleshoot with are the speaker and the LED :=-
mstechca is offline   Reply With Quote
Old 10th July 2005, 06:36 AM   (permalink)
Greetings,
A capacitor with a working voltage of at least 48 volts will work. A 50Volt capacitor will work but as with anything pushed to it's maximum limit, it's life will be limited. A manufacturer may use a 63 Volt capacitor to save their $0.02c worth.
I am with Mstechca, I like to double the rating, so 100 Volts it is!
Also if it will be mounted near anything warm like a heatsink, large resistor or such, use a high temperature capacitor (105 degrees celcius) for longer life. I guess you are rectifing 120 Hz and not high frequency so ESR is of no consideration?
Laplink is offline   Reply With Quote
