When I was little I use to bang a t.v remote, now its not working
Can chips be damaged by collisions, like falling to the floor ? What about other components like zener diodes and transistors ? |
No you can throw chips in the wall and thay will still work.
Its most probobly a lose conectin.Or it may be one of those universal remotes that need to be set for certan TVs
Number one fatality for remote controls is the ceramic resonator that is used to produce the 38khz carrier frequency. Cheap to replace. Often they are placed on the PCB in such a way that if the remote is dropped the resontaor will "slap" into the PCB, destroying the resontor. When I replaced them, I always glued them down.
As Someone Electro said, check for broken solder joints also, especially the IR LED. |
Oh yea the crystal!How cod i foget that.
Another common problem is dry joints on the 'large' decoupling capacitor, and as already said, dry joints on the IR LED, and broken ceramic resonators. Incidently, while the IR modulation is about 38KHz, it's derived from a ceramic resonator about 455KHz.
what exactly is a ceramic resonator and how does it work ?
whats a decoupling capacitor ? on my remote the ceramic resonator has two pins and has this written on it: b455 e 20 m U what does this mean ? What if I throw a pentium againt the floor, will it still work properly ! |
The thing you are talking about is proboby a transistor.
Its a boxy yellow plastic or metal rounded thingy that has 2 (a crystal) or 3 (a resonator) pins. If you throw an pentium in the flor you will break its fragile pins.If you throw an DIP chip in the flor you will only bend its pins (you can bend them back) Check for lose conections.You may want to take it to someone who knows electronics stuff and has the tools.
wops that thing your talking about is an resinator.(sily me)
The part with the number 455 on it is a ceramic resonator, 455 Khz. You can get one from another remote, or even some AM portable radios, to test if it is OK.
(permalink) | |||
But if something just "falls on the floor", then it should still work. If it fell in a pool of liquid, then you may be in trouble.
-=: The best low-priced components to troubleshoot with are the speaker and the LED :=- |
If you dunk it in water whithout the batery it shod work.You wod just have to dry it out before puting in the batery.
One guy here put an cell phone in water for 24 houres and and then he picked it out put the batery in and it still worked.
Is there any conventional way to check the ceramic resonator, such as using a multimeter, how would a pro check it ?
Whats the difference between a quartz crystal(used in watches) and a ceramic resonator ? |
(permalink) | ||
