| | #1 | ||
I have found the following information from google groups on Superregen receivers: Quote:
Also, what is the "highest modulation component" for TV signals?
__________________ -=: The best low-priced components to troubleshoot with are the speaker and the LED :=- | |||
Hi MStechca, If the quench frequency is less than double the highest modulation frequency then you will hear a new "beat" frequency that is the difference between the two frequencies. FM stations broadcast stero subcarrier frequencies up to 53kHz and frequently broadcast 67kHz SCA music for stores and restaurants. The 67kHz is also FM, so its highest frequency is about 74kHz. If the quench frequency is only 75kHz then you will hear 1kHz to very high interference in the audio. Some FM stations broadcast stock market data or something up to 100kHz. So maybe the quench oscillator should be set to 120kHz to avoid hearing nterference. TV stations also have multiplexed stereo sound, so they also broadcast subcarrier frequencies up to 53kHz. I don't know if they broadcast other stuff above that, they probably do. Now here is another problem with a super-regen to add to its list: 1) Transmits RF interference. 2) Has high distortion and poor treble because the positive feedback makes its single tuned circuit to have a bandwidth too narrow. 3) Has poor stations selectivity because it has only a single tuned circuit. 4) Is very easy to overload with stong local stations. 5) Poor sensitivity for FM because it must be tuned to the side of a station's carrier for slope FM detection. 6) Very noisy when the signal is strong. 7) Beat frequency interference between its quench oscillator and the stations modulation frequencies. :cry: :cry: :cry:
| frequency, optimal, quench |
