Old 6th June 2005, 03:00 PM   (permalink)
TKS
Default Connecting an electrial motor
i all,
i need to know how to connect a mono phase 2BHP motor to the 230volts wall socket
the engine is made for the 230 alternating power...
but what i don't untherstand is...
i have 3 leads + an earth...
and also an huge cap..(looks like an piece of tube..)
Soow does any one knows how to connect it??
are 2 leads 230volts and one N???
or all of them L??
i'm 100% sure it isn't an 3phase engine.. (looked at the metal housing)
also i have no idea how to connect the cap to the engine,
perhaps thats something to do with it..
hope you all can help..
TKS
TKS is offline   Reply With Quote
Old 6th June 2005, 03:13 PM   (permalink)
I would suggest the capacitor is a starting capacitor, which is also why you have three leads. You might try mentioning what colour the leads are, someone might know which ones which.
I don't know a great deal about electric motors, but I think that one wire is neutral, one is live, and the third connects to the capacitor. The other end of the capacitor connects to live, it creates a phase shift, which starts the motor moving.
Old 6th June 2005, 04:52 PM   (permalink)
On 230VAC single phase here in the states both are hot legs white and black should be 115vac to ground and 230 to each other the other wire soulds like it goes to the cap wire color would be help full so would type of motor and what ever other info you could give.
MARINE1142 is offline   Reply With Quote
Old 6th June 2005, 05:19 PM   (permalink)
That doesn't apply in Europe, we have 'proper' 230V mains, single phase - your mains is only 110/115V - the 220/230V is probably two phase?.
Old 6th June 2005, 06:03 PM   (permalink)
TKS
Default ok here we go...
the colours are black, brown and blue.. and ground..
Tks
i'm almost sure that nigel has the solution..
Old 6th June 2005, 09:03 PM   (permalink)
Default Re: ok here we go...
Tks
A quick google found a few interesting pages, you might like to have a look at http://www.leeson.com/products/techref/sphase.htm.
Old 7th June 2005, 08:05 AM   (permalink)
TKS
Default mhhh
well on the manual was a website adress
soow this is all the info i cant get..
(i have the 1,5KW version)
http://www.franklin-electric.de/en/p...s/4-1ph-3w.htm
IF you read it a bit you will see: Capacitor start motor, FE control box required..
mhh now i read it again and i see that FE means: The use of a Franklin Electric control box offers you maintenance-free long life operation by providing high starting torque and motor protection.
Would it bee an good idea to buy one?? i think we need one..right??
i know read in an pdf that from 1,1Kw - 3,7KW i need Cap Run and Cap start..
any one ideas wich values the 2 have?? in the package came only one cap?
Tks
[Edit:]
http://www.franklin-electric.de/en/p...n_Internet.pdf
page 30
Old 7th June 2005, 08:30 AM   (permalink)
This may be useful to you:
http://www.lmphotonics.com/single_phase_m.htm
Try measuring the resistance between the leads - a lowish value indicates that the two leads are legs of a winding, a high / open circuit value would indicate that you have the capacitor in your circuit.
Phasor is offline   Reply With Quote
Old 8th June 2005, 01:54 AM   (permalink)
I believe the motor will have two windings, that is 4 wires, plus two for the cap means there are internal connections already made. I suggest you temporaly connect two wires together, then connect to the mains with a large (100watt or more) lamp in series to limit the current. If nothing happens, you are connected across the cap, try a different connection. If it hums but does not turn, you are getting close but need to try again. If it turns slowly, that is the proper connection and you can take the lamp out of the circuit.
Russlk is offline   Reply With Quote
Old 8th June 2005, 01:10 PM   (permalink)
http://www.franklin-electric.de/en/p...%20CT_Engl.pdf
Note figs 16, 21, 23
FRIED is offline   Reply With Quote
Old 9th June 2005, 11:24 AM   (permalink)
got it fixed
3Faze is offline   Reply With Quote
