Old 24th May 2003, 03:47 AM   (permalink)
Default What is a Vericap Diode ?
Dear All,
Whilst I was going through some ckts, I came across a Vericap diode. I do not understand this. Is it similar to any other diode or is the mecanisum is different? Why a vericap is necessary. Appreciate your help.
Ravi :?
Ravi is offline   Reply With Quote
Old 24th May 2003, 05:27 AM   (permalink)
A varicap diode, is a diode which has a characteristic of decreasing its capacitance, as the reverse voltage increases. Often used in AM radios.
Phasor is offline   Reply With Quote
Old 24th May 2003, 05:53 AM   (permalink)
often used in AM radios
It is often used in FM radios. Not in AM
Old 24th May 2003, 06:01 AM   (permalink)
oops ops: I couldn't quite remember - took a stab in the dark...
Old 24th May 2003, 07:20 AM   (permalink)
Also used in AM radiotuners e.g .:BB113 5....120pF
Sebi is offline   Reply With Quote
Old 24th May 2003, 11:57 AM   (permalink)
Default Varicaps
Most low-leakage silicon diodes can be used as variable capacitance diodes when used in the reverse direction ("Varicap" is actually a tradename similar to "HexFET"), although your run-of-the-mill silicon swithing diode has a smaller capacitance and small capacitance change. "Varicaps" are bred for larger capacitances and capacitance changes and are available in a variety of different characteristics. Another popular series of "Varicaps" are the "MVxxxx" series of type numbers.
Dean
R.I.P.
Dean Huster is offline   Reply With Quote
Old 26th May 2003, 01:52 AM   (permalink)
Default Thanks
Thanks everybody for valuable information.
Ravi
Old 26th May 2003, 08:25 PM   (permalink)
It can be found in AM radios. It's only frequency aware - not modulation type.
pebe is offline   Reply With Quote
Old 27th May 2003, 05:12 AM   (permalink)
Oops sorry! But I have never seen a varicap in AM receiver.
Frequency in AM is constant and therefore if a varicap diode is used in AM receiver, it will just act as a constant value capacitor for a chosen carrier which means there is no point in using a varicap. A constant value capacitor can also be used in its place.
Whereas in FM, frequency is releted to modulating signal and so any change in frequncy will affect the capacitance of varicap which can be used to demodulate the FM signal.
Well, this is what I am thinking, but there may be AM circuits which uses this diode. IF anyone has one, I would like to see it.
Old 28th May 2003, 04:00 PM   (permalink)
Yes, the carrier frequency of any ONE AM station is constant - as distinct from FM where it varies.
But you need to tune to more than one station and that means varying the local osc frequency. Either by using a variable capacitor altered by a knob, or by varying the volts on a varicap if it is a digital tuner
Old 28th May 2003, 05:55 PM   (permalink)
I see. So you were talking about voltage controlled digital tuning.
Old 28th May 2003, 06:49 PM   (permalink)
Yes, or it could be analogue - controlled by a pot.
Old 28th May 2003, 08:07 PM   (permalink)
Old 29th May 2003, 08:40 AM   (permalink)
Default Audio Varicaps?
I'm sure I remember a circuit for an analogue synthesiser's voltage controlled filter using a "real" varicap, I know I have diagrams using signal diodes in a ladder network as "cheapo" varicaps - same theory (as Dean said way back in this thread).
I need a memory upgrade ...
My head is full !
mechie is offline   Reply With Quote
