my full question(how do u build a led that pulse to music of a personal cd player or a tape player???? is it posible????? and can it run on a 9v battery?
and if it can, can u tell me the parts i need and can u give me a diagram of what it should look like when it is done? just starting in to the world of electronic's and i under stand the basic's and sum of the hard stuff so can someone anser me??????? :?: :? |
Making a circuit to flash an LED in time with the music isn't easy for a nooby. It needs a low frequency audio filter, a rectifying circuit and an LED driver. Maybe you could plan it so the LED driver also rectifies the low frequency audio from the filter stage. Then you need to design a printed circuit board or Veroboard layout for it. Perhaps a kit is best for a nooby.
Uncle $crooge |
hey is u can can u please at least make a simple or conplex don't care circuit board layout for what i am trying to make?! and if some of the part's are very complex if u can make a ledgend showing what it is, anyway thank's for replying to my question, i will make it if u can make the circuit board layout for my project and i will tell u if it work's, so thank's and hope u or someone help's me with my question. :!:
Hi Nooby,
How is your circuit going to pick-up the signal? If it is a microphone, then it needs a preamp in addition to he other stuff. If it is from the wires that connect to a speaker, then it is much easier.
Uncle $crooge |
That said, I think there are some circuits on this board that do what you want. Use the search function and type in 'LED pulse to music' . You may have to fiddle around with the wording but try it. Make sure you have the 'search for all terms' option selected.
I'm no electronics god, i just talk too much. |
If it's connected to the speaker output of a stereo, just the LED, a rectifier diode and current-limiting resistor is probably all that is required. Simple.
Instead of the rectifier, two LEDs could be connected back-to-back in reverse parallel. :lol:
Uncle $crooge |
look for "stereo VU meter" at talkingelectronics.com interactive website.
That will give you a start.
-=: The best low-priced components to troubleshoot with are the speaker and the LED :=- |
a i don't want a stereo VU meter i just want ear phone in put in to my cd or radio that will be connected to a circuit board that will make the led's pulse to the music of the song that will have a input for ear phones
ok that's all im asking, i just want to no if some one can tell me if it's posible if it is can thay tell me what part's i need and have a circuit board drawn so i will no how to build it, that's it. |
i think i understand what u mean but what does a rectifier diode and current-limiting resistor look like :?: :?: :?: :?
i can draw and make that but i just need to no what it look's like. |
i have a pic of what a rectifier diode look's like but i couldn't find out what a current-limiting resistor look's like.
rectifier diode :arrow: ![]() |
A rectifiying diode looks just like... a diode :P ... Same thing for the current limiting resistor... It's just their place and connections in the circuit that gives them their particular behavior... Rectifier Diode: connected in parallel with two nodes, it 'rectifies' = limits the voltage of the two nodes to its drop voltage. That is if u connect a 1.7V diode, no more than 1.7V of voltage will be across the two nodes. Current-Limiting resistor: If u wanna limit the current entering a node, just place a resistor in series with that node, it will limit the current, based on the voltage applied to the node... I hope this helps ya :wink: :!: |
................. :shock:
what i still get u mean :cry: :idea: im going to make a circuit board pic 4 u , u tell me if it's right :!: |
hey audioguru can u tell me how it goes :?: :?:
"example: the +, conected to the LED, conected to the swich, conected to the -" ok :wink: that's what i need u to do if u can |
A stereo VU meter is 50% of the solution. Hook it up to an amplifier output, then hook the amplifier input to your CD player earphone jack. Once everything is correct, you will see an LED go with the music.
Hi Nooby,
This circuit might work. EDIT: Current-limiting resistor values increased to reduce max LED current. Value of rectifier filter cap increased so that LED indicates for about 50ms.
Uncle $crooge |
