A1 yes close together
A2 c6 and c13 to 5.2 to 30pf Lm2931A5.0 to 78Lo5 c12 to 33pf (and c4 is 100nf A3 (problem? :roll (but that might be my rubbish multimeter :roll: ) |
Hi Monkeytree,
Your substituted parts should be fine except the 78L05 might operate poorly when the battery voltage drops below 8V. My low-dropout regulator works fine when the battery voltage drops to 5.6V. Did you build the FM transmitter on a pcb?
Uncle $crooge |
i am using 6 AA batteries in a holder giving out 9.75V so that 'should'
be okay? and yes i did do it on a pcb. |
And what's the purpose of Q3 anyway ? Frequency : 98.3 with C4 @ 8.2 pF Interesting obserwation : regardles of V1 the oscillations are attenuated. Either when it gives single pulse (between 10 and 20 us) or works continiously. What's going on ? |
I consider simulators a waste of time, particularly for this type of circuit, where it's not likely to even get close. |
Hi Monkeytree,
You can troubleshoot the circuit by measuring DC voltages at its important places like the collectors and emitters. Since it operates at VHF, measure the voltages with a 100k resistor connected in series with the red lead of a working high input resistance (10M) multimeter.
Uncle $crooge |
(permalink) | ||
For my bad luck, that's exactly my task - to provide working simulation, but the circuit must also "look like" real. Not to build an actuall device, or just simulate the spectrum. Just to make such strange so-called-simulation |
An RF amplifer (at least for FM) doesn't need to be linear, and there's no advantage to it being so - in fact there are advantages in it NOT being so!. This sort of RF amplifier would commonly be used in class C, with no bias at all - I don't know if Audioguru has tried that? (connect R8 to 0V rather than 9V) - but I suspect the 47K is intended to bias the transistor towards class B, as there probably isn't enough drive signal to work in class C?. |
Hi Nigel,
I tried Q3 without bias as a class-C amplifier but it didn't have enough input level to produce much output power. With it biased on, the input signal causes it to amplify very well, and I think it operates in class-B as you say with a very high output voltage swing. Someone 'scoped one to show its output voltage (35Vp-p) far exceeding the supply voltage due to the high Q of its tuned circuit ringing. I don't think the sim program knows anything about Q or RF. It just thinks the transistor's collector is shorted to the supply, and displaying the battery's voltage being modulated. :lol:
Uncle $crooge |
... life :evil: Anyway : does anyone have an idea how to prove sim's inability to accurately perform the calculations WITHOUT assebling a circuit ? The more maths, then better. By the way : please forgive me my strange questions. On holiday I'll take up real electronics. |
Best Regards, Peter Soy un hombre muy honrado... :| |
(permalink) | ||
Class A (the only one you appear to be considering). Class B (biased to 'not quite on', how I think Q3 probably is?). Class C (not biased at all, switched by the signal). Class D (used purely as a switch, either hard ON or hard OFF). Class A is usually used in preamps. Class B is usually used in push/pull ampifiers, but usually modified to class A/B to improve distortion figues. Class C is usually used in RF power amplifiers, only conducts on positive half cycles, relying on the tuned circuit to 'ring'. Class D is usually used in 'digital' amplifiers, as it's always either hard ON or hard OFF, it's dissipation is accordingly low. |
Well...newbie is newbie Thank You very much Nigel, for your patience and advice. Question for everybody : is there by any chance ready PCB for this circuit ? (mod 3, without IC ). And what the antenna should look like ? Best Regards, Peter
Hi Antey,
I made mine with Veroboard (with strips of printed copper) and its antenna is just a piece of wire 30 inches long hanging down. I will probably use a telescopic whip antenna from an old RC car transmitter. My Veroboard layout for mod-4 looks like this:
Uncle $crooge |
But... I'm afraid to ask I'd like to thank everybody once again.
