Old 5th May 2005, 05:27 AM   (permalink)
Default soldering trouble
has any body got any tips on how to solder surface mount resistors there size is Length 2mm,width 1mm, height 0.5mm
monkeytree is offline
Old 5th May 2005, 08:52 AM   (permalink)
Default Re: soldering trouble
Very carefully :lol:
Use a VERY small pointed bit, small tweezers, and head mounted magnifers - and have lots of spare ones, you're likely to lose quite a few!.
Old 5th May 2005, 10:42 AM   (permalink)
all i did was have a closer look at them and lost three
how big is the chance that they will be engulfed by the solder?
Old 5th May 2005, 10:47 AM   (permalink)
You have to use very small amounts of solder, then there's no chance.
Old 5th May 2005, 12:07 PM   (permalink)
Using very small amounts of solder necessitates using very thin solder (0.5mm or less).
Possibly a flux pen might help too.
Phasor is offline
Old 5th May 2005, 05:12 PM   (permalink)
Another thing to watch out for is them popping up! You need to hold them down with the tweezers while you're soldering. Otherwise, when your iron melts the solder, it just pivots and raises like a toll road barrier when you stick in your change.
There\'s no graphic in my signature.
I don\'t know your IP, and I\'m not trying
to hax0r you. You\'re welcome.
bonxer is offline
Old 5th May 2005, 10:00 PM   (permalink)
Get some reverse action tweezers - the kind that open when you squeeze them. It makes handling small things much easier.
Here's how I do 0603 components: Put a little bit of solder on one of the the pads (the bottom or right pad is usually easier if you'r right handed). Get the compenent in your tweezers so you can hold it flat against the PCB. Melt the solder you put on the pad and slide the component into the pool until the solder sticks. Let the solder cool and then let go with your tweezers (don't try to let go while the solder is still melted it almost always will move your component). Now go back and solder the component to the other pad.
bmcculla is offline
Old 6th May 2005, 03:50 AM   (permalink)
Default reply
You could use solder paste or do what nigel said, very thin solder and tewzer's and a magnifing headset.
Or use a toaster oven.
Robotics is heaven in my book.
Roboticinfo is offline
Old 6th May 2005, 06:44 PM   (permalink)
I find that with solder paste I have a terrible time with the problem bonxer mentioned - the solder doesn't stick on one side ant the component sticks strait up - even when I use hot air. The iron and tweezers is much faster and more reliable for me.
bmcculla is offline
Old 6th May 2005, 07:12 PM   (permalink)
I can confirm that bmcculla's method is the best that I've used. I'd do as he recommends...
I don\'t claim to know everything... I just want to know everything.
TV-Engineer is offline
Old 7th May 2005, 03:29 AM   (permalink)
I have not yet attempted to do any SMD soldering.
If I understand bmcculla's point correctly, he recommends that we don't use solder paste. I assume that the solder is resin cored, ie. has paste inside it.
Len
ljcox is offline
Old 7th May 2005, 05:36 AM   (permalink)
good job i got a hundred of each value because i only had to solder 8 and i lost 13(once you have droped them you cant find them agian)
thanks for the help i did as was commonly suggested and it was suprisingly easy
