| New Member | Hi. I'm currently working on a project and it requires debouncing circuit. I have a 74ls192 up down counter. The clock for the up and down pins will be push buttons. I need to have debouncing circuit for it. |
| Experienced Member | Choose one... |
| Experienced Member | http://www.embedded.com/showArticle....cleID=18902552 Lots of reading and detail. At least there's pictures. |
| Experienced Member | R2 reduce the discharge current, and prevent the switch erosion. When You have a 10A microswitch no problem if omitted. |
| Experienced Member | Of course then again, I'm the kind of guy that likes to charge capacitors up to around 35 volts or so and then strike the leads against a piece of metal to short, make it spark, and give a nice popping sound. The temorary welding effect is a bonus feature. :twisted: |
| Experienced Member | In order to ensure reliable operation, switch contacts need at least 5 Volt across them when open and at least 1 mA of current through them when closed. This prevents the build up of an insulating film on the contact surfaces and therefore eventual failure. Len |
| Experienced Member | Hex inverted with schmitt trigger. 7414 LS or better. I also found that an AND gate works good, just tie one high and use the other input for the switch signal. HC series works best here.
__________________ Your website has been blocked |
| New Member | Bumping a dead topic, sorry, but if one could make the circuit work with an inverted switch, would the NOT gate still be needed? |
| Experienced Member | Quote:
But this subject has been covered before, see for eaxmple http://www.electro-tech-online.com/v...nce+suppressor Len | |
