Old 2nd April 2005, 12:11 PM   (permalink)
Default how do you get perfect pcbs?
anyone got a secret of how to make decent circuit boards?
monkeytree is offline
Old 2nd April 2005, 01:26 PM   (permalink)
I've always gotten the best results using the photoetch method. I used to spray coat my own boards with photoresist, but: a) it's a real pain to get the coating perfect & free of defects, b) GC electronics doesn't make the spray resist anymore. So I use positive-acting presensitized boards now. Also, instead of printing my artwork onto film myself (which doesn't work all that bad), I print finished artwork on paper at 2 times scale, then take it to a local graphic arts guy (who makes decals, bumper stickers, etc.) who photographically reduces the art to 1x onto film for me. The traces and pads on his films are very opaque with NO pinholes. He charges me $6US per shot, and I think it's worth it. I get the results I'm looking for.
JB
jbeng is offline
Old 2nd April 2005, 01:44 PM   (permalink)
If you are using the laser printer- transfer method, practice, practice, practice. I make a sandwich between two pieces of glass and put a piece of cotton cloth over the paper. I use metal spring clamps to hold it all together and put it in the oven. The oven is set on pre-heat to 400 degrees F. As soon as the temp hits 400, I take it out and let it cool, then soak the paper off. I print on the pasted side of prepasted wallpaper, which soaks off easily.
Allow for some spreading of the ink in your layout, 10 mil spacing won't work. I can layout TSSOP packages, but don't do it if possible.
This is my latest layout:
Russlk is offline
Old 2nd April 2005, 03:12 PM   (permalink)
Hi Monkeytree, as I said in the other topic, I'll now go through how I do my boards. It's going to be long, but I hope it helps you. It'd be handy to know which country you are in, because I can tell you then where I get my board from, etc., it's the best board I've used so far and has allowed me to get incredible results for the first time.
First thing I do is draw my schematic in Eagle, available in a free version which is what I'm using, with limited board size (fine for most hobby circuits) from www.cadsoft.de.
I then change to the board layout part of the program and set out the components, which I move around as I'm routing it. If using the autorouter, I save it before autorouting so that if I need to change things to get it to route better, I can reload the unrouted layout. Here's my present project after I've manually routed the entire board (autorouter isn't always very good):
It's then ready for printing. I use Staedtler Lumocolor Inkjet Film (Transparencies), grade 0.10mm, part number: 639 30 A4 H. They work very well. My printer is an old Epson Stylus Color 740 and is capable of maximum resolution of 1440x720 dpi. In the printer preferences, I choose print media as Photo Paper, and set it to the highest resolution (as if printing out a photograph on to glossy photo paper). In the Eagle print settings, I make sure I choose 'mirror' so that the layout prints out mirrored, since the view in Eagle is from the top of the board. I then print out the layout 3 times, using a splicer to cut off the print-out from the A4 transparency sheet each time, so the print-out doesn't go through the printer again and get smudged to death. Each time cutting off more of the sheet, so when overlayed the pieces of transparency get smaller and thereby give room for sellotape to stick each one to the one below. They must be precisely positioned over each other, especially if there are tracks close together. Here are the three of them overlayed and stuck together:
Now for the board. I use pre-coated photo-resist board from www.maplin.co.uk (in the UK, hence why I wondered where you live), which seems to be excellent. I cut it to the correct size, peel off the protective plastic over the copper and then quickly position the transparency over it. Then I place a piece of glass from a photo frame over the lot (heavier the better) and, using a couple of plastic can tops from my foam cleaner and freezer spray, place a UV face tanner over it all, so the UV source is about 3 inches above the board. I used a test strip and exposed patches for different times to find out what was needed - 1 minute exposure didn't quite do it, but 2 minutes and above was perfect, so I expose for 2 minutes using a countdown timer. Here is the face tanner I use (it's my wife's, she's very lenient and accepting of me ), cos I can't afford £100+ for a little PCB UV box when I make, what, one board a year?
After exposure, unlike some photo-resist boards I've used, you can't see any hint of the layout on the board yet really. I quickly take the exposed board into my developing room (the kitchen... oops, I've already got some chemical or other on the stainless steel sink, which is now stained steel, and my wife was not overly impressed. I can't help being a mad scientist at heart!) and dunk the board into a tray of Carbonate-based developer. Rocking it back and forth constantly, I stand there and forget timing it, I just watch until I can see the layout magically appear and carry on until there is no photo-resist left between close-together tracks, etc. My developer is a bit past its best now, and it takes around a couple of minutes till I'm happy it's done. Doesn't much matter, I could leave it in there for 5 minutes and it wouldn't over-develop, Carbonate is so much more gentle than the caustic soda (Sodium Hydroxide developer) I used to use back in the day.
When that's done, I rinse the board and place it in warm Ferric Choride solution, and stand there rocking it for as long as it takes, sometimes 20 minutes or so - boring, but it makes it etch faster. Sometimes I pour the acid back into my jug and warm it some more in the microwave (how long till the inside of the microwave has disappeared, I wonder, and how will my wife react... ho hum) and then pour it back into the tray. Speeds things up no end. Having dried the board, I get my little 12V PCB drill out and start drilling the holes, which is easy thanks to Eagle leaving a hole in the middle of each pad, so the copper gets removed there, giving a simple reference point for drilling, and making it easier because the drill can bite straight into the board material without swirling around on shiny copper, trying to get a grip and cut. In fact, the comparitively hard copper actually acts as an auto-centre to push the drill bit towards the centre of the pad. Here's the board after etching and drilling:
Then it's simply a case of populating the board and soldering everything in place. I print out a non-mirrored image of the board with components showing but not the tracks - as they make it hard to see the parts and values properly - and then use that to see exactly where I need to place components, and their respective orientations. Here it is with parts soldered in place:
And from the top, complete with ugly looking cables running to the speakers and audio output on the soundcard, along with a large heatsink bolted to the IC:
So there you have it. If you're still with me and haven't flat-lined or fallen, snoozing, to the keyboard, this might help you or anyone else to obtain good results. I've been doing boards for around 7 years now, and these are the best I've ever managed, so it's been quite a course of trial and error, I'm just glad that I finally discovered this method and good board from Maplin.
Best of luck to you,
James
There\'s only one impossibility in this life - thinking up a good signature for profiles...
HandyMan is offline
Old 2nd April 2005, 03:35 PM   (permalink)
thanks for the advice, and i did not fall asleep i had been using Ferric chloride etchant from www.rapidelectronics.co.uk (tools and production equipment) i got the wrong stuff
Old 2nd April 2005, 04:03 PM   (permalink)
Ferric Chloride is the right stuff for the job, what's wrong with it?
HandyMan is offline
Old 2nd April 2005, 05:18 PM   (permalink)
I make double sided boards using the positive photoresist PCB, I thought double sided would be very difficult to line up but it isn't it is actually pretty simple.
Using my PCB program I print out the two sides on transparencies with my laser printer (no smudging and crisp lines) then place the two side, toner side in together and line them up while looking through them, tape them together making a pocket(one side untaped), slide your board in the opened end then tape it shut. Carefully place the board in between two sheets of either glass or thick plastic and tape them together, this will sandwich everything and help stop it from moving. Place it under the flourecent lamp for 5 min on each side, remove and develop. Then etch using your etchant, I use Ferric Chloride in a jug with a heater and a small submersible pump to move the fluid around.
Works like a charm!
Ron
RonH is offline
Old 2nd April 2005, 06:53 PM   (permalink)
i think i need to keep it at the right tempreture
check out my website, I have a tutorial for etching boards from start to finish using toner transfer.
http://eegeek.net/electronics/tutori...cbtutorial.htm
I have never had any problems even with surface-mount parts. if you get your toner density right, and your ironing technique down, you don't get much spreading of the toner during transfer so you can get away with very fine traces (yes, even 10 mil spacing)
note that one main difference between my method and "the usual" method is that I set my iron to only 2/3 heat, rather than all the way. For those of you who routinely do toner transfer, I suggest you give that a try at least once... since I've started doing it that way i've had 4 boards in a row come out perfect (one rather large one, see the pics on my tutorial page), with minimal trace spreading or blobbing, and few to no broken traces, etc.
Also, I use a totally different etching method than most. I prefer sodium persulphate over ferric chloride because it's almost as fast, but it's crystal clear so you can really see the progress. I do my etching in a ziplock baggie, which allows me to use a very minimal amount of etching solution (1/4 cup of water, a couple tablespoons of powder usually) and also allows me to agitate the solution by hand, and focus on areas that are etching slowly. and when I'm done with the solution, i can just dump that tiny bit down the toilet and throw away the bag.
EEgeek.net
evandude is offline
Old 2nd April 2005, 07:45 PM   (permalink)
I'll have to give the 2/3 heat a try next time.
I also use the sodium persulphate and I like it.
Jeff Zimmerman
jrz126 is offline
Old 2nd April 2005, 09:34 PM   (permalink)
I do the exactly the same an Handyman.
Will never use any other method.
I use universal developer-Sodium dydroxide Free
It's from www.rsaustralia.com cat. no. 690-849
This developer does not have aggressive over-developing characteristics of Sodium Hydroxide developers
It's expensive but so gentle.
Screech is offline
Old 2nd April 2005, 11:18 PM   (permalink)
Hanyman, what version of Eagle do you have? I have 4.13r1 and it does not have holes in pads, which makes drilling difficult. Also, the print function does not work. I thought it was something left out in the free version, but maybe I just don't know how to do it?
Russlk is offline
Old 2nd April 2005, 11:27 PM   (permalink)
I have 4.13r1 also. Do you mean the pads on the screen do not appear to have holes? Mine are on screen and present when printed out, even if the track I lay seems to cover the hole on the layout.
The print function works for me, although I found that it seems quirky, and to get mine to print at all, I always have to click on 'printer' within the print dialogue box and then pretend to change the printer settings, etc., before clicking on 'OK' and 'Print' which then takes me back to the original box. When confirming the job in that box, it starts printing properly. Otherwise it will claim to be doing the print job but nothing will happen at the printer end.
HandyMan is offline
Old 2nd April 2005, 11:40 PM   (permalink)
Thanks for the reply, yes, no holes any time. The printer problem is the same with me, I had not figured out how to make it work. I have been in contact with Eagle email help, I will ask about the pad holes.
Russ
Russlk is offline
Old 3rd April 2005, 04:20 AM   (permalink)
ahaha i use the paper-oil-photo method
What I do is print the art out at 2x scale, and then take it to school to have a measly 20c spent reducing it to 1x on normal paper.
Then when i get home, i soak the paper in oil to make it translucent. Then place the oiled-artwork onto the PCB and expose away...
My 20watt halogen lamp is capable of exposing a board in 20-30 minutes. Works a treat. without the oil a board takes 2 hours!!
edit: you might want to gently wash the board down with detergent after exposing!!
This is an example of an oiled art printout.
www.winpicprog.co.uk - Great PIC language tutorials.
pike is offline
