Originally Posted by brodin It is for the circuit you helped me with, the current limiting circuit. The voltagedrop over the diode/diodes are critical. I cant use 2 1N4148 (0.7v each). Then the output current gets to low under 12V input.
How many LED's are you putting in series?, you should have something like 11V available with a 12V input. The voltage drop acros the diodes isn't critical at all, but if you're trying to run too many LED's in series you will run out of voltage.
If you're running out of voltage, changing the diodes (assuming you can find something at 1V?) will only increase the voltage headroom by 0.4V - which isn't very much.
You could always split your LED's into two chains, and have two transistors and two 22 ohm resistors - you can connect the two bases together, and use the same pair of diodes and feed resistor to set both base voltages.
But if i have a lower voltage drop, say 1V and a lower resistance value, then 12V works fine.
So it don't have to be constant, but it have to be rather close to 1V to work fine.
Someone said to me that a 1N4001 had a 1V drop. Would that diode work?
It's a standard silicon rectifer, it will have about 0.7V drop, like any standard diode junction. Under high current demand it will increase somewhat, as all junctions do - but it's not running with high current.
