Old 13th October 2007, 11:24 PM   (permalink)
thats cool.
i am planning to built below circuit.can u guys tell me what components shld i change to make it work on 12v(12-15v) supply.
http://members.tripod.com/~foz11/DIY...al_speedo.html
just name the components i'll modify the diagram and will provide eagle board so that other can make one easily.
student1616 is offline
Old 14th October 2007, 12:39 AM   (permalink)
The circuit in your your new link will bpow up the 7.5V zener diode voltage regulator at pin 9.
The circuit you had needed a 12V or higher supply. It also needs to have a 10k ohms output pot because the 350 ohm pot is dragging its supply voltage way down.
It is very important to know if you have breaker points or a swinging magnet thing called variable reluctance as an input to determine if you have the correct IC.
audioguru is offline
Old 14th October 2007, 04:21 PM   (permalink)
thanks for the reply guru
my vehicle uses CDI ignition system.so i am sure i'll be getting pure sine wave.
and it will be great if some one could give me the rough diagram of LM2917,LM3914 powered with 12v supply
forgive me if i sound dumb
regards
Old 14th October 2007, 05:04 PM   (permalink)
If your car doesn't have breaker points (nothing to do with CDI ignition which also could have breaker points) then it has a low level AC input and you should use the LM2917-8 which has only 8 pins. The LM2917 with 14 pins has a positive input only for use with breaker points.
Get the tachometer working before adding an LM3914 display.
