| Experienced Member | Hi all, Does anyone have any info on how to "fake" a specific frequency crystal? I need a 14.00000MHz rock and I can't afford to have one made. Prices on custom crystals have jumped over 4000% in just the last five years. So, is there a way to take some other frequency, do some circuit magic, and stuff it where it's needed? Thanks.
__________________ <ckd> "Chance favors the prepared mind."--Louis Pasteur (1822 - 1895) |
| Experienced Member | Why "fake" it? Old PeeCee mainboards have salvageable assemblies. 14.318 MHz was a common frequency. Mouser has HC-49/U AT-cut 30ppm rocks for US $0.40 - much cheaper than they used to be. And a CSA-309 type at 28 MHz at US $0.83 that could be used with a /2. The parts needed to construct a tuned oscillator, although easily done, would cost more than a crystal, and be much less stable and more temperature sensitive. <als> |
| Super Moderator | Yes, there are lots of alternatives, such as using a PLL locked to a higher (or lower) frequency crystal. But a lot depends what you want the crystal for?, isn't 14MHz an amateur band? (or at least part of it). |
| Experienced Member | Quote:
Yes, I believe you are correct, but I'm not using it for that. I have a SW converter that outputs to an old AM radio. It has a 1.00000MHz offset, and since I already have 2.5, 5 and 10MHz time signals from WWV on it, I wanted to get 15MHz, too. I don't want to have to fool with it too much, so obviously, the best way would be a 14.00000MHz crystal. Any thoughts?
__________________ <ckd> "Chance favors the prepared mind."--Louis Pasteur (1822 - 1895) | |
| | (permalink) | ||
| Super Moderator | Quote:
If that isn't possible, use a PLL and lock a free running VCO to a different crystal frequency - say 1MHz, with divide by 14 from the VCO to the phase comparator. | ||
| Experienced Member | A converter covering that range will almost certainly include switch-selectable tuned circuits for the particular band. Changing the injection frequency will not be the only modifications necessary. Find an old ARRL Radio Amateur's Handbook; there used to be (and probably still are) circuit examples for WWV converters for 5/10/15/20 Mhz. <als> |
