Old 20th March 2005, 08:03 PM   #1
Default High voltage transformers
Im currently working on a project that will contain very high voltages (up to 36KV) is there transformers available to handle such high voltages?
Wrighty is offline
Old 20th March 2005, 09:58 PM   #2
Default Re: High voltage transformers
Yes, the electrical supply in the UK is transmitted at 300KV - the obvious problems with high voltage transformers are the insulation requirements, this could be a problem for you.
You don't give any clue as to the application, or the specification, but you might have to have transformers specially made?.
You should also be VERY aware of the dangerous voltages, assuming there's any sort of current capacity it's likely to be almost certainly fatal!.
Old 23rd March 2005, 11:26 AM   #3
36 kV is well within the range for modern color
monitor (and television) H.V. circuits, albeit at
low currents. What is your application?
<als>
fredsm is offline
Old 24th March 2005, 04:53 PM   #4
yes I know that the mains is transmitted at that sort of voltage so there is no power loss due to the heat dissipation in the resistance of current, I am a electronics technician! My application is for generation of a big voltage obviously with minimal current (pA).
Wrighty is offline
high, transformers, voltage
