+ Reply to Thread
Results 1 to 4 of 4
Thread: third method of SSB generation (weaver's method)
  1. #1
    samcheetah Newbie
    Join Date
    Dec 2003
    Location
    Pakistan
    Posts
    874
    Default third method of SSB generation (weaver's method)
    can someone explain me the third method of SSB AM signal generation which is also known as the Weaver's method.
    i understand the other two methods which are the filter method and the phasing method. the main drawback of the filter method is that it has a filter which should have an ideal behaviour. and the drawback of the phasing method is that a 100% phase shifting circuit is not realizable in real life circuits.
    but the third method uses both filters and phase shifter circuits. so it should have the disadvantages of both the other two methods. am i right????
  2. #2
    stevez Good stevez Good
    Join Date
    Apr 2003
    Location
    Rochester, NY
    Posts
    2,115
    Sam - you might find what you need in the ARRL Handbook or similar amateur radio publications. Check the ARRL website - may be an article or two on SSB.
    stevez
  3. #3
    samcheetah Newbie
    Join Date
    Dec 2003
    Location
    Pakistan
    Posts
    874
    okay thanx stevez. actually i have the ARRL handbook for Radio Amatuers 2001. but this method is not explained in it. i have found a couple of sites that do explain it a little bit. but i was just wondering if someone on electro tech knows about it so i can discuss with him.
  4. #4
    samina Newbie
    Join Date
    Aug 2009
    Location
    Bangladesh
    Posts
    35
    samcheetah, I am also facing the same problem as u faced before, if u get the solution please let me know that. I will remain grateful to u.
    samina
+ Reply to Thread
Tags for this Thread
