Hello I am currently making a project in which enables me to turn applications on and off whilst I am not at home. I decided to get the HT9170B from Rapid and use in conjunction with a programmable chip to read the outputs but I am having several problems. I used the datasheet found at this URL http://www.rapidelectronics.co.uk/im...g/82-4078e.pdf. And used application circuit 2 with the suggested value resistors/capacitors. However I got no output on any of the pins when using a mulitmeter. I am fairly new to electronics so no doubt I have done something wrong. Any help would be much appreciated,
Jack |
Experienced Member
The OE (pin10) of the IC is said to be internally pull high on P.3 of the above datasheet. But I sense something not quite right in the description because it mentioned clearly pulled down but no mention of pull HIGH.
Try connecting a 60K to 150K resistor from this pin to Vcc and measure the response again. Hope this help.
L.Chung |
