Hello. I was wondering how a low budget color detection can be possible. I have seen in another threat that 3 LED (R,G,B) can be used and measure the intensity of light. But i have seen the LEGO MINDSTORM sensor that has only on LED (i think). I there such a component?
Thank you |
There are single LEDs that has RGB in it, so that it is a multicolor LED.
I'm no electronics god, i just talk too much. |
Thank you zachtheterrible for your reply. So i guess mesasuring the reflection is the only solution? :?:
Thank you |
One solution I saw blasted a white LED at the sample and three filtered receivers measured the intensity. You had to put the standard sample under the detector and store the resulting readings as a "color". The simple system I saw was a demonstration for sorting m&ms into their various colors.
Dean
Dean Huster, Electronics Curmudgeon Contributing Editor emeritus, "Q & A", of the former "Poptronics" magazine (formerly "Popular Electronics" and "Electronics Now" magazines). R.I.P. |
If three LEDs could do it, a single multicolor LED i would imagine could do it. It has four leads, one for red, one for green, and one for blue, and one for ground.
Thank you for your replies. I will try it out.
Hello. I back on this project and now i really need to find something simple and quick. The RGB LED would be well outside my budget. I think it should work with only one trans-receive IR module. However it would be great if someone could suggest a IR component to buy.
Thank you. |
A trans-receive IR module works with IR, which is infrared that has a frequency lower than visible light. It might pickup a small reflection from a red object, because the frequency of red is near the frequency of IR, but it wouldn't pickup an IR reflection from another colour.
Uncle $crooge |
Are you trying to resolve shades of the same colour or just differentiate between, say, red, green and yellow? What ambient lighting is there or is this a sensor that gets very close to (touches?) the object? Would a simple torch bulb be OK for illumination and three LDRs, each with a colour filter (primaries or secondaries or "Quality Street" sweet wrappers) work as detectors?
I need a memory upgrade ... My head is full ! |
Lego mindstorms have a IR module which can distinguish varius color (i tried it) and has only one receiver and one transmitter. Thank you for your quick replies... |
(permalink) | ||
It is not the same as color resolution.
Uncle $crooge |
So what you are saying is that i will use a IR transmitter and the IR receiver indication will vary (enough to be detected) according to the color (black or white) of the object. I there any particular IR transceiver that you suggest me to use??? Thank you. |
Black and white are not colors. They are the absence of reflected light and the presence of reflected light. Since you are using only IR, your indication will have a few unknown color variables. A bright green or blue reflected color would give the same indication as a dim red reflected color, and many other color combinations would be the same.
I wouldn't use IR to detect colors, I would use an RGB LED or 3 separate ones, and 3 light detectors with color filters. With the correct choice of LED and filter colors I would have very good resolution of any color.
Uncle $crooge |
A few friends of mine use a light detecting resistor and an OP-AMP to detect colours.
According to them, the resistance of the LDR was dependent on the colour of light incident on it. They first cliberated the opamps for a few colours. I do not believe that this shall be very accurate but defnitely low cost.
Bharath Bhushan Lohray. M.Sc. Electronics. |
Thank you for your answers.
Since i have already oredered a IR tranceiver for distance measuring purposes, I will test it next week and i will let you know for the result. Thanks again. |
