| I am trying to connect a non-inverting amplifier (op-amp 741) output to a relay. The amplifier gives me the output that I need which is about 7V. However, the moment I connect this to the relay input, the voltage drops to about 2V and thus the relay does not switch. I'm using a electromechanical relay which is normally open(6V relay). Why is this happening? Is a 2V relay available in the market?If yes, please let me know where. Thank you. | |
| this is normal... 741 is not designed to provide big output current. it was designed to have big gain. nowdays, thins are a bit different so there are OpAmps that can handle much more current. another thing is that realys are not normally driven by OpAmp. You need digital (on/off type) signal to operate relay properly. If the 741 output is working like that in your application, all you need is a transistor to get the current big enough to turn on relay. if you need more help, try posting your circuit. | |
| Thank you for your quick reply. I'm a little unsure about whether a relay is turned on by voltage or current or both voltage and current? Do you mean I have to use a transistor to amplify the output current from the 741 op-amp? What models of op-amp will provide me a larger current? Thank you. | |
| panic mode wrote Quote:
you can use simply AC 187 and no need to change op-amp | ||
A relay's specifications will include the coil's resistance and the nominal operating voltage, or small range of voltages. It is the current through the coil's winding ( caused by applying the voltage across it ) which produces the magnetic field necessary for the relay's operation. | ||
| The mention of using an AC187 transistor brings back fond memories. It's an old germanium transistor in a cylindrical metal case! It doesn't even need base current to turn on, just warm it a bit. You want to know what "thermal runaway" is? Ask an AC187, its the expert. | |
