| I need to have a Camera's Strobe Flash 2 rapid times aprox. 400 mill seconds apart. Im using a Pic micro for the delay, and a OPTo triac ( MOC 3020 ) for the switch. If I understand right a Traic will not shut off untill the current is removed so the flash Cap will be to low for a second flash. Any suggestions for turning off the Triac? Thanks for looking | |
| could you post the schematic you have so far , maybe we could make some suggestions.. | |
| Oooh, good question! I suspect- this is just a theory- that there's a low capacitance high voltage cap being fed from the main high voltage cap through a resistor, and the main cap is isolated from the tube by an SCR or the like which isn't turned on while the tube is triggered for the preflashes. So the preflash only runs on the smaller cap. The resistor is sizes to be a large enough value to assure the flash quenches without draining the main cap, but small enough that the preflash cap will recharge off the main cap to fire a second time before the main flash. | |
| I'm Not trying to design a new strobe circuit. What I'm trying to do is trigger a strobe to flash twice withend 400 ms. | |
| | (permalink) | ||
so its not really a triac ..its a bilateral switch..designed to drive a triac.. Quote:
| steveo , why not copy a circuit that allready does what you want..?? | |
