Old 3rd February 2005, 09:16 AM   (permalink)
Default Electronic motors
Hello,
I would like to know the function of the pins (I/O) we can find on this kind of motors. On the picture there are 2 Minebea electronic motors I have, I think from a damaged videocassette, on these ones there is an small PCB with a small connector of 6 pin.
I would like to play a little bit with them and then understand the function of each pin but I donŽt know what kind of inputs I should apply on them to make them run...
Thanks.
Regards from Mallorca.
YouŽll never know enough...
2PAC Mafia is offline
Old 3rd February 2005, 10:30 AM   (permalink)
From the look of them (particularly the left hand one), I would suspect they are stepper motors.
Try rotating them gently by hand, do you feel a large number of small 'steps' as you rotate it? (probaly 200 or so for a full rotation).
If they are steppers, you have to provide stepping signals for them, there are loads of stepper tutorials on the net - try google.
Old 3rd February 2005, 10:36 AM   (permalink)
Hello Nigel,
yes, I turned them and I felt those steps you mean. OK, then IŽll look for step motors if I find something useful at google.
Thanks.
Old 3rd February 2005, 06:37 PM   (permalink)
MINI STEPPER MOTOR: NMB Brand, model # PM35S - 048. 24V DC Operation, 50ohm coil resistance, 6 wire. 7.5degree step angle.
Measures 42mm long, 32mm wide & 15.5mm high:
http://www.oatleyelectronics.com/stepper.html
NMB has a website as well , that should be worth exploring.
It may seem like a good idea at the time but.. never stir your cold coffee with a soldering iron.
tansis is offline
Old 4th February 2005, 09:59 AM   (permalink)
From http://www.nmb-minebea.de/produkte/index.htm
PM55L-048 Ű 55 mm x 26,2 mm 7,5 GRAD < 20,0 Ncm
PM55L-096 Ű 55 mm x 26,2 mm 3,75 GRAD < 16,0 Ncm
Phasor is offline
Old 4th February 2005, 11:43 PM   (permalink)
You will need a certain binary sequence to run steppers, and possibally a transistor driver array.
Most steppers have a standard code, however, companies like to be different.
to test the sequence, simply put each lead of the stepper as a input to the base of a transistor (a general one will work), and put a LED in relation to the collector so it turns on when pulsed, and the emmiter to ground using a 10 ohm resistor. Each lead will have it own transistor in sequence from pin one to the last. Spinning the shaft will repeat the sequence over and over. One of the pins is power.
Luckily those steppers are 4 bit binary driven.
Your website has been blocked
Juglenaut is offline
