+ Reply to Thread
Page 2 of 2
First 1 2
Results 16 to 22 of 22
Thread: Dual full rectifier supplies
  1. #16
    Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,723
    Quote Originally Posted by TheOne
    I was thinking in terms of a light or no load and the danger of max input voltage to the regulator which is -40V. The -ve section will still work as a 1/2 wave voltage doubler where the top will be normal full wave rectification. The dissipation in the -ve regulator will be much higher than the +ve one.
    Ron, you have to analyze it over more than 1 cycle to see that the voltages from the caps will add.
    I was looking at the transformer as 12.6VAC across the terminals. Now I see it says "CT". So what is the voltage across the bridge? Isn't a center-tapped transformer spec'ed at end-to-end-voltage, i.e., wouldn't it be 6.3VAC from CT to each end? Even if the AC voltage is twice what I simmed, the magnitude of the negative output voltage is less than the positive output.
  2. #17
    TheOne Newbie
    Join Date
    Oct 2004
    Location
    USA
    Posts
    464
    Ron, I think the difference is that I assumed that he is using a center tapped transformer and just neglected to show the center tap connected to GND. If it is not a center tapped arrangement then the -ve voltage will be lower. I have not drawn in the C.T and transformer, but set up the incoming AC to act in such a way. Here I have taken the effort to use a transformer and simulated both conditions.
    The one is a 12.6V + 12.6V and the last a 12.6V only.
    \"You can\'t make a circuit fool-proof, cause fools are so ingenious!\"
  3. #18
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,790
    NO! - the centre tap must not be connected to ground, it's a bridge retifier circuit, the centre tap isn't used - giving the full 12.6V from both windings to feed a single rail. His original diagram was drawn quite correctly.
  4. #19
    Sebi Newbie
    Join Date
    Jan 2003
    Location
    Hungary
    Posts
    1,717
    This cct also work with one bridge.
  5. #20
    Sebi Newbie
    Join Date
    Jan 2003
    Location
    Hungary
    Posts
    1,717
    oops! TheOne, Your upper cct make a total shortcut for transformer...
  6. #21
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,790
    Quote Originally Posted by Sebi
    Yes, a standard fullwave rectifier, using a centre tapped transformer (or in your diagram two transformers), generating split supplies.
    But this wasn't what he wanted to do.
  7. #22
    TheOne Newbie
    Join Date
    Oct 2004
    Location
    USA
    Posts
    464
    But his original circuit won't work with one winding at 12.6V (unless he removes the GND from the bridge and connects it as a centertap 12.6V+12.6V) as the -ve voltage is then too low to feed the -ve 12V regulator as Ron also found in his first simulation. Will only work with a doubler setup. One of the first posts say something about a center tap transformer on the diagram. :?
    Sebi, yes! (fixed), like I said the -ve side will be 1/2 wave doubler and the +ve side standard full wave.
+ Reply to Thread
Page 2 of 2
First 1 2
Tags for this Thread
