Old 17th January 2005, 10:19 PM   (permalink)
Default How to calculate how much current is used?
if i want to calculate how much current my circuit draws when two resistors are connected in serie at 12VDC, I have to add the value of the two resistors ,before using ohms law, rigth[/u]
Lac is offline
yes
Styx is offline
Old 17th January 2005, 10:25 PM   (permalink)
but..uhh.. connecting the resitors in paralell would mean that less current is drawn? :?
Lac is offline
Old 17th January 2005, 10:47 PM   (permalink)
more current would be drawn since the equiv. resistance is 1/r1+1/r2=1/Rt
which is less than R1+R2 when they are in series.
and less resistance means more current drawn.
Jeff Zimmerman
jrz126 is offline
no you just asked for series.
two resistors is series produces a net resistance of hte sum of those resistors
R = R1 + R2
Via Ohms law.
V = I*R
For resistors in parallel the total resistoacne is
1/R = 1/R1 + 1/R2 + ...
Styx is offline
Old 17th January 2005, 11:04 PM   (permalink)
oh sorry i meant:
Connecting the resitors in paralell would mean that MORE current is drawn.
Then it would basically to better to connect components in serie, rather than parallel, as far as it is possible?
thanks.
Lac is offline
Old 18th January 2005, 01:05 AM   (permalink)
that depends on what are you trying to achive - define "better".
if you take everything out of your TV and connect it in series,
i don't think you would get significant improvements other than
chance to buy new one.
panic mode is offline
Old 18th January 2005, 03:12 PM   (permalink)
In terms of "better" I mean that the circuit consumes less current.
Lac is offline
Old 18th January 2005, 04:03 PM   (permalink)
As already mentioned, it depends entirely on the circuit, you use serial or parallel connections depending on what you want to do - or just use a single resistor of the correct value.
Nigel Goodwin is online now
Old 18th January 2005, 04:09 PM   (permalink)
two 2k resistors in parallel would be the same as two 500R in series.
parallel-series, series-parallel, they are just tachneques to get a value of resistance.
what voltage are you working at and what current do you want.
That will tell you the overall load impedance, from that it is just a matter of calculation
Styx is offline
