Old 17th January 2005, 04:15 PM   (permalink)
Default PLL
Where can I find the simplest phase lock loop circuit?
If I can use just transistors or simple logic gates to produce it, that would be great.
mstechca is offline
Old 17th January 2005, 04:31 PM   (permalink)
Default Re: PLL
The CMOS 4046 is probably the simplest and easiest PLL to use, building one from discrete devices is likely to be a LOT more complicated.
Old 17th January 2005, 07:33 PM   (permalink)
I want to learn how to build my own. The more I learn, the smarter I get.
mstechca is offline
Old 17th January 2005, 08:23 PM   (permalink)
You need a ref frequency, VCO, XOR gate for a phase detector, LPF for smoothing and a divide by N counter if you need the output F to be N(times) the reference frequency. This could be implemented using discrete chips.
\"You can\'t make a circuit fool-proof, cause fools are so ingenious!\"
TheOne is offline
Old 17th January 2005, 08:31 PM   (permalink)
If you get the datasheet for a PLL they ususally have a block repesentation of what is in one
Styx is offline
Old 17th January 2005, 11:37 PM   (permalink)
Without telling my age, I was experimenting with electronics before IC's were available. To build a phase lock loop in those days was next to impossible. As it has been said before the 4046 is the easiest to build a PLL with. Add a 4017 divide by 10 counter and you got it all. The 4046 has the VCO and the phase detector in one package. Learning how the individual blocks work and then how the system works should be satisfying.
k7elp60 is online now
Old 18th January 2005, 06:59 AM   (permalink)
Actually not!, a common feature of TV's was a discrete PLL, even available as an update for many really old sets - it was called 'flywheel sync'. By using a PLL around the line oscillator stage it reduced picture 'tearing' on weak signals - by the mid 60's it was universally used in production TV's.
Old 18th January 2005, 11:31 AM   (permalink)
Default Re: PLL
Not sure I really agree with that ... I suppose it depends on how wide a 'lock range' you want and wierd stuff like that but I have built a variant of The Poor Man's Caesium Clock, using an XOR detector and bandgap-tuned crystal oscillator, nice and simple and works OK (after some tweaking of monostables in the TV line seperator ??).
mstechca
Read that article (link) - I think it's a good into to PLL useage.
I need a memory upgrade ...
My head is full !
mechie is offline
Old 18th January 2005, 12:44 PM   (permalink)
Default Re: PLL
Rather more complicated than a 4046 though, that has everything in one DIL package (including two types of phase detector), and requires very few external components.
Old 18th January 2005, 02:34 PM   (permalink)
Default Unphased and still looping !
mstechca
I was searching for info about Thandar LA160 and stumbled across this ...
http://www.holmea.demon.co.uk/Ethernet/PLLQA.htm
I thought it might be of interest ?
Nigel OK, maybe I should concede this one - I think the discrete circuit is good for seeing how a PLL works though! (and 1 XOR, a varicap and Xtal oscillator isn't that complex :wink:
My head is full !
mechie is offline
Old 19th January 2005, 12:17 AM   (permalink)
74HC/HCT4046 has a third phase detector
http://www.semiconductors.philips.co...046A_CNV_2.pdf
FRIED is offline
Old 22nd January 2005, 09:08 AM   (permalink)
someone knows the pll and vco that can works up to 70Mhz???
Zener_Diode is offline
Old 22nd January 2005, 09:45 AM   (permalink)
personally i'd just get an LM565 and learn how to use it from there...
and Zener_Diode, an LM565 should be able to handle 70MHz easily...
plot is offline
Old 22nd January 2005, 11:16 AM   (permalink)
In it's datasheet is written "vco maximum frequency is 500Khz.
http://www.chipcatalog.com/National/Datasheet/LM565.htm
And I need 70MHZ....
Old 22nd January 2005, 11:42 AM   (permalink)
Generally you would use a discrete VCO for high frequencies, the rest of the PLL generally runs at far lower frequencies (with the VCO divided down).
