Old 12th January 2005, 08:44 AM   (permalink)
Default help identify these **56K beware**
this may be impossible for some/easy for others - i'm a newb so i'm not sure. I took a LED taillight apart from a wrecked motorcycle and need help indentifying 2 pieces of the circuit. the LED's and resistors are not a problem, but if anyone can shed some light on what the name and function of the 2 mystery pieces it would be greatly appreciated. (sorry for the large pix)
earz_cd is offline
Old 12th January 2005, 08:59 AM   (permalink)
I don't really know what they are, but the labeling does suggests that they are diodes and zener diodes. Try running diode tests across them.
checkmate is offline
Old 12th January 2005, 09:17 AM   (permalink)
like i said - i'm a newb. i'm not quite sure how i would do that. I know i need a DMM, but what kind of readings am i looking for?
earz_cd is offline
Old 12th January 2005, 03:02 PM   (permalink)
Look up possible partno's (then search Google) against the codes here
http://www.tkb-4u.com/code/smdcode/smdcode2.php
\"You can\'t make a circuit fool-proof, cause fools are so ingenious!\"
TheOne is offline
Old 12th January 2005, 05:24 PM   (permalink)
I would say the ZD1 is a Zener Voltage regulator, and the 2 Diodes are general purpose 1amp or slighly more.
Your website has been blocked
Juglenaut is offline
Old 12th January 2005, 09:53 PM   (permalink)
JC - 2J -> BAL74 (Siemens) SOT23 fast switch diode 50V 0.25A
27C -> 27 Volt zener diode - Mf unknown - Power unknown
at least 27V is what the book says, but i'm unsure how a 27V diode would end up on a motocycle...
Exo is offline
Old 13th January 2005, 01:54 AM   (permalink)
that can't be right b/c SOT23 is a three prong SMD and the JC-2J above is only two prong.
and the circuit is not made by the motorcycle manufacturer. It has a KOITO marking on the board.
earz_cd is offline
Old 13th January 2005, 02:18 AM   (permalink)
Sot 23 is the size (2 by 3 mm) - 2 or 3 prong - it has the same name
i don't care who made it. it came of a motocycle and they run on 6V, 12V ?? - why would they use a 27V zener in that ? ...
but the databook says 27C - zener 27V
Exo is offline
Old 13th January 2005, 02:37 AM   (permalink)
cool thanks for the info.
any idea on the other piece - possibly where i could find one?
earz_cd is offline
Old 14th January 2005, 10:40 AM   (permalink)
Hope there is no DC/Dc converter in there.
Zeners are used as protection for other devices and in such case the zener voltage is higher than dc voltage.
Gajanan Phadte
gmphadte is offline
