+ Reply to Thread
Results 1 to 2 of 2
Thread: Speed control for a 3 phase motor?
  1. #1
    ed sparks Newbie
    Join Date
    May 2003
    Posts
    2
    Default Speed control for a 3 phase motor?
    Can I have a cheep alternative to a motor drive. I need to control the speed of a 3 phase, 1.5Hp, 63 output rpm, 460Vac motor. Please Help, My boss is cheap.
  2. #2
    Super Moderator kinjalgp Newbie
    Join Date
    Oct 2002
    Location
    INDIA/USA
    Posts
    1,855
    There is no cheap method to control speed of AC motors. The speed eq. of AC motor is :
    S = 120 * F / P
    Where F = AC signal Frequency & P = No. of Poles in motor
    Thus speed depends on F and P
    But P is constant for given motor
    Thus speed can only be controlled by varying the frequency.
    For 3-phase motor, you require a 3-phase variable frequency PWM generator (you can use microcontroller). This PWM signal needs to be linearly amplified to get approximate AC output for motor which can either be done using MOSFETs or IGBT (more prefered).
    All these are minimum requirements of AC drives which won't come cheap.
+ Reply to Thread
Tags for this Thread
