| | (permalink) | ||
You can do PWM in software (and so use any pin), but it's fairly complicated to write, it doesn't run anywhere near as well as the hardware one does, and it takes lots of clock cycles - the PWM hardware takes no processor clock cycles at all!. There are various PIC's which have two PWM outputs, this makes them VERY useful for motor control in a small robot or model. | |||
| okay Nigel ill note that actually we did a simulation in our lab in which we had to build a H-bridge circuit and drive a motor with it and measure the voltages and the currents. the circuit that our teacher gave us was simillar to this one. the motor was being driven by the emitters. uptil that day i had only seen H-bridges in which the upper transistors were PNPs (or P channel MOSFETs) and the lower ones NPNs (or N channel MOSFETs) so the motor was driven by the collectors. i told the teacher that the configuration that you have given us is wrong and it should be the other way round. he said that it doesnt matter, you just have to make a path for the current to flow. could you you explain how the base current is low and the voltage drop is higher | |
| The selected C on the gates (the value of about 10nF was needed) of the N devices may solve the spike problem at the rising edge but there's still a problem on the falling edge.
__________________ \"You can\'t make a circuit fool-proof, cause fools are so ingenious!\" | |
| As I said It must be tuned. Increase R4 to about 7k | |
| Makes no difference even with a 20K. You most probably need a big cap at the top as well.
| Cap's at the top seems to work.
By having 2 separate pins, i am able to complement the inputs to each other. Therfore, i dont think any shoot-throughs would happen. This is what happened during my circuit testing. I had my forward output HIGH and my REVERSE output LOW. I inputted a 100% duty cycle PWM signal into my LOWER FET. No overheating occurred. Then when i changed my cycle to 50%. LOTS of distortion occurred and suddenly it starts to HEAT up real quick. However, having the reverse and forward output complementing each other, i dont think any shoot-through occurs. Anyway, thanks for the great circuit. I definitely would change to yours. The ON OFF timing seems FAR better | ||
That specific model must have been flawed as it made no real difference if I had a 1k gate resistor or 100k!
__________________ \"You can\'t make a circuit fool-proof, cause fools are so ingenious!\" | ||
Then the base current, this is governed by ohms law, and is equal to voltage across the resistor divided by the value of the resistor. Because the base has to go high, you've got no voltage to work with - so the base can't go as high as 12V (again restricting the output voltage). Assuming the base can get within 0.3V of the 12V rail, and the transistor has a gain of 100, and it's driving a motor requiring 1A. This gives a base current of 10mA. So to calculate the base resistor, 0.3/0.01, giving only a 30 ohm resistor feeding the base. The values used in the circuit shown will limit the output current considerably, resulting in a much lower voltage to the motor, and the transistors running MUCH hotter than they need to. There's also the obvious disadvantage of two 30 ohm resistors permanently across the power supply, wasting lots of your battery power! (one from each side of the H-bridge, either top or bottom, depending how it's switched). My 'best case' calculation above would only supply a theoretical maximum of 10V from the 12V supply - but the values in the circuit would be far less under load. With the transistors the other way round, things get MUCH better - for a start the voltage drop in that configuration is much less - 0.2V or 0.3V may well be possible, depending on the transistor. You've also got MUCH more voltage to play with for your base current, instead of the paltry 0.3V I suggested above, you've now got a whopping 11.3V instead! - so you don't need 30 ohm resistors anymore!. If we assume a worst case of 0.5V drop across the transistors, we now have a reliable 11V for the motors, from the 12V supply, with the transistors turned hard ON, and running a great deal cooler. | ||
| But With Common-Collector there is chance of shoot-throughs (common-emitter doesnt have this) I'm not saying common-emitterCommon-collector is the better circuit, equally I am not saying Common-collector is the better one (although this is the arrangement I would go for). Both topologuies have their advantages and disadvantages and their uses. Best thnig about engineering: No real wrong answers, just better answers | |
| you get them during a HIGH to LOW input to the leg - TheOne has already shown that with FET-based bridge leg. he same stands up true for BJT phase leg. There is a finite time it takes to switch a device ON and OFF. It is worse for switching OFF the P-type/PNP since it takes alot longer than the N-type/NPN to turn-on. Thus there is a finite time when both devices are ON (be it in their active region) Thus they dissipate alot of power and over-stress the devices. There are two causes of shoot-thoughs. Bad driving and thus turning on both switches in a leg OR during a transition during the switching period. It is due to teh switching times that I always put interlock into my commutation stage, thus ensuring that when I turn OFF the device that is on (in a leg) there is a period before I start to turn ON the other device, thus giving the other device to turn-off fully. This time is based of the switching charateristic of the switches being used It is this type of shoot-through that I was stressinb when Fabbie said his FET's were getting hot. I think he interpreted that shoot-through suggestion as a control "both switches ON" type. When I ment a switching shoot-through The switching shoot-through will be inherent in hsi design. Without incorportating a dedicated drive per switch and added interlock logic, the topology I chose slows down the gate voltage to the FET's and thus slowing down the time it take a gate signal to reach the threshold voltage level. Essentally a crude method of making interlocks. | |
In any event, S/C failure of any one device in an H-bridge is likely to be fairly catastrophic in a similar fashion :lol: | ||
| Yer I know - H-briges are are not he most fault-tolerant things around. makes FMEA's easier "what happens if this occurs - Blows up" "what happens if this occurs - Blows up" "what happens if this occurs - Blows up" ... Yes tying Gates to the other side will eliminate the posiibility of a shoot-through since it's turn-on/off is now descretly tied to the the other device turning-off/on I just wanted to stess that there are other factors IF someone wanted to up the power handling on a H-bridge and was not giving switching times of power devices the respect they need | |
