Old 26th December 2004, 10:07 PM   (permalink)
Default GPS Antenna
I just got a GPS module (superstar). The annoying thing about it is the antenna. What is so special about a GPS antenna?
It has about 5cm of wire(too shoort). The guy who gave it to me said that it couldn't be longer without being amplified.
Can i make my own antenna for a GPS receiver that is more suitable for my project?
brodin is offline
Old 27th December 2004, 05:23 AM   (permalink)
GPS is a high frequency operation. the higher the frequency, the shorter the antenna. the antenna is ther for a reason.
wut the guy probably meant by "amplifying" was to match the impedances. you may be right, that you could get better reception w/ a longer antenna (im not sure of the frequency of GPS, and therefore how long an ideal antenna would be) but it would be pretty hard for you to re-match the impedances.
BTW, wut is your project?
zachtheterrible is offline
Old 27th December 2004, 06:24 PM   (permalink)
Default Re: GPS Antenna
It is a patch type antenna made from double sided pcb, but with a high dielectric constant to enable the reduction in physical size of the antenna.
The signal level received from a GPS satellite is around -126dBm at 1575 MHz for a good signal. Many GPS antenna's will have a pre-amp in it to amplify the signal before more noise gets picked up in the cable from the antenna to the receiver.
You can try. http://home.iae.nl/users/plundahl/antenne/patchant.htm
Notice that the size is already much bigger than the commercial units using ceramic for the dielectric. This person attempted to get a smaller size by using air as a insulator between the two layers. The connection point of the coax is also very critical to get the correct impedance match.
\"You can\'t make a circuit fool-proof, cause fools are so ingenious!\"
TheOne is offline
Old 27th December 2004, 08:45 PM   (permalink)
I don't really need to get the antenna smaller. But the problem with it is that it requires quite much "free sight" to the sky. I don't know, maybe all GPS are the same. It does not work indoors. Not even inside(beside) the window. I have to be outside to use it. Is this common for all GPS receivers. Would it be possible to change this whith a better antenna?
As you can see, i am very new to GPS receivers :wink:
brodin is offline
Old 27th December 2004, 08:55 PM   (permalink)
And by the way. How many sats is recomended to get a rather acurate result? I had 5-6 when i tested it today in the car with the antenna by the front window.
brodin is offline
Old 27th December 2004, 09:01 PM   (permalink)
You need three satellites for a fix if you know the altitude. Otherwise you need four.
JohnBrown is offline
