Originally Posted by doctor_prox They are the correct way round. The supply is a 12v lead acid battery and i have a 47uF cap between ground and +3.3v |
As I see it there are only two possibilities?, either it's wired incorrectly, or you have faulty components somewhere - possibly both chips are faulty? (which seems highly unlikely). Another possibility is an external component, the 47uF S/C would probably cause this as would anything S/C on the output.
Is the chip mounted on a heatsink?, if so, is it insulated from the heatsink?.
It's a simple enough circuit, there's not many possibilities.
