Old 24th December 2004, 06:49 PM   (permalink)
Default Sine wave from 555?
Friend of mine argued with me that you can't get a sinewave output from a 555 timer. Simulation below shows you can. Cost him a few pints! :wink:
LC oscillation frequency will be more stable than RC mode.
\"You can\'t make a circuit fool-proof, cause fools are so ingenious!\"
TheOne is offline
Old 25th December 2004, 01:31 AM   (permalink)
i'm somewhat dumbfounded at this diagram. The output of a 555 cant be sinewave, unless you have something to smooth off those corners.
:? please explain
www.winpicprog.co.uk - Great PIC language tutorials.
pike is offline
Old 25th December 2004, 02:06 AM   (permalink)
:? please explain
Note that I picked my words carefully,
and not said, you get a sine wave from the output of the 555 :wink: there's a difference!
TheOne is offline
Old 25th December 2004, 04:51 AM   (permalink)
Owned
I agree it is possible to get a sine wave.
I wonder what is used in high quality inverters.
Your website has been blocked
Juglenaut is offline
Old 25th December 2004, 05:32 AM   (permalink)
i think inverters use bridge circuits (half bridge and full bridge) and they produce a pure sine wave.
by the way TheOne which software is this that you use for simulation
samcheetah is offline
Old 25th December 2004, 06:20 AM   (permalink)
Proteus Pro. You can download a lite version free
http://www.labcenter.co.uk/
TheOne is offline
Old 25th December 2004, 07:08 AM   (permalink)
Originally Posted by njbibin
tell me how it work
It is fairly simple. We have a 10kHz pulse input. The L and the two C's forms a resonator (pi-filter) at the required frequency, giving 180 deg phase shift (higher order harmonics attenuated after passing through the resonator), and together with another inversion going through the 555 gives a total of 360 degrees. This in-phase feedback together with > 1 (~4) gain through the 555 satisfies the condition for sustained oscillation.
Graph of the Fourier (spectrum) analysis show the harmonic content at the input of the resonator and how only the fundamental remains at the output.
TheOne is offline
Old 25th December 2004, 08:27 AM   (permalink)
And just to prove that the 555 acts only as a invertor like I previously explained, I replaced the 555 with a logic invertor. The result is the same, oscillation at 10kHz
TheOne is offline
Old 25th December 2004, 08:59 AM   (permalink)
In fact it does not matter what we use for the invertor, as long as it has enough gain to overcome the losses around the circuit, you will have oscillations. Here on the left, a common emitter amplifier with gain >1 completes the loop, and once again oscillations at 10kHz. Even a JFET will do nicely as shown on the right.
TheOne is offline
Old 26th December 2004, 06:22 AM   (permalink)
And lastly, Zach one specially for you. Here we even kicked your IRF510 into oscillation. The pot on the gate is set to be near the gate threshold voltage (~2.5 - 3V)
TheOne is offline
Old 31st December 2004, 09:22 PM   (permalink)
Could you attach the files of those schematics, I'm trying to learn how to use Proteus Pro demo and it would make things seasier for me to browse through the circuit and check how did u configure the values and stuff.
Rasengan is offline
Old 31st December 2004, 09:43 PM   (permalink)
I don't have all of them anymore as I modify old ones into new circuits. If you PM me I could email you the ones I still have. Also I am not sure that all will run on the demo version cause of the models.
TheOne is offline
Old 2nd January 2005, 03:48 PM   (permalink)
Here's another inverter you can use.
0x34
0x34 is offline
Old 2nd January 2005, 04:02 PM   (permalink)
effectively all this is doing is harmonic-scrubbing of the actual outout of the 555 which is a squarewave
still good, could never scub a sinewave that well
Styx is offline
Old 4th March 2008, 06:14 AM   (permalink)
thanks for the methods....
leejok2003 is offline
