| can anybody Please recommand me on some FM Transmitter/s? a good one.. thnks :-) | |
__________________ \"You can\'t make a circuit fool-proof, cause fools are so ingenious!\" | |
| wut r u looking for? high power? bug (cuz i got a really good bug)?
| I want to hear about this bug, if nobody else! Show us! | |
| this is the coolest transmitter mainly because it has such good performance off of only 3v. Since its 3v, two AA's can be used, giving it MUCH more battery life than your regular ol' 9v transmitter. @ a range of about 50 feet, this transmitter lasted for FIVE days! of course it would last longer if you keep getting closer and closer. oh yeah, and the transmitter was overpowering a very strong local radio station for those 5 days. i plan to find a receiver that i can modify to go above the regular 88-108 MHZ and then im sure that i can get even more range out of the transmitter.
| I'm trying to do what your doing atm. But i'm trying to to it digitally. The output signal is a digital wave. Theoretically you can make an extremely powerful transmitter. possibly stronger than the licensed stations aswell. It would have to be crystal locked with a PLL. This would also be very very accurate and have virtually zero frequency drift. were still looking for a pll of high enough frequency range (30mhz+) *Note however this is for extremist in this field who want power :twisted:
__________________ www.winpicprog.co.uk - Great PIC language tutorials. | |
| i dont get wut ur saying pike. r u saying that ur trying to build a low voltage transmitter that is extemely powerful?
If you search on these forums, there was a link (not long ago) to just such a PLL transmitter, which applied the modulation in the phase lock circuit, giving broadcast style deviation and accurate frequeny settings. I presume unlicenced broadcasting in Australia is severely illegal?, as in the UK - and certainly if you're looking at higher powers than commercial stations you are going to be VERY easy to catch. It's also going to be expensive to build high power transmitters, and complicated as well - with a need for expertise and specialised test equipment. Assuming the laws are similar to the UK?, if (when?) caught EVERYTHING connected with it will be confiscated - transmitter, audio equipment, CD's, computer - the LOT. Plus a potentially very large fine, and possible jail sentence. If caught, I would advise grovelling in court - I used to know a guy who got caught three times! (only with low power), the first time he was fined, the second time a bigger fine, the third time he grovelled embarrasingly in court and escaped with a warning :lol: In all three cases all his gear was confiscated and destroyed, including his complete record collection (it predated DC's). | ||
| ok maybe not powerful enough to take over other stations, but certainly powerful enough for 400m radius (1200ft??) Most of those kits that say they transmitt 1km, is bogus. In the end they only transmitt 30m. If I cant find a pll suitable i'll get the low power digital kit, and amp it up with lots and lots of 2n2222's. Or even a mosfet!! Yes I know laws are put in place. but as long as i'm not transmitting over emergency service signals (if they failed, someone could die as a result) the signals however would be transmitted very rarely. zach: I'm pretty sure that the power transmitted doesn't solely rely on voltage, but also the amount of current being converted to electromagnetic radiation.
| | (permalink) | |||||
Suddenly dropped from multi-kilowatts to milliwatts!. Quote:
__________________ \"You can\'t make a circuit fool-proof, cause fools are so ingenious!\" | ||
__________________ I'm no electronics god, i just talk too much. | ||
| Hey, The PDF link dosent work!! Im looking for a good FMTransmitter Chip, which will be able to handle deviation and harling.. I heard something with crystal will be good, Its for a cartoy. thnks | |
| Ive just found an alternative. I'll utilise the space in the amatuers band which has much less restsrictions. This also means i'm changing over to AM which is fine by me. I'll build a crystal locked version set at 20mhz by a crystal. Then amp it up. Now for the recieving end... Yes, you are right nigel. I haven't got the faintest idea on how to build a transmitter, but i'm extremely will powered on this!!! On the other hand i'm more proficient on the digital side of things. I think the saying goes: 'where there's a will, there a way'something like that. Much Like zach, with his persistent questions on these boards!! 8)
