I have a JVC AV-20CM5 that has a horizontal line in the middle. Some have described this as a "white line" but in my case it shows color, motion, etc. of what is happening on TV. But, of course, it's just a few pixels tall.
The person here with the exact same model had the same problem: http://experts.about.com/q/1749/3380300.htm The reply was: "The vertical IC is shorted. Replace it and check the resistor and diode that supply B+ to it." Do you think the person is correct? If so, how difficult do you think this repair would be without any previous TV repair expierence? The FAQ here ( http://repairfaq.ece.drexel.edu/sam/tvfaq.htm ) looks very detailed which I plan on reading if I decide to give it a shot. Might as well if the TV will otherwise go to a landfill (which I'd rather not do). Thanks! [Edited to correct direction.] |
If you have a vertical line, it indicates that there is vertical scanning and no horizontal scan. The fact that there is a line shows that the line stage is partly functioning as far as supplying the EHT voltage. I would look for a open circuit (bad connector, plug etc.) to the horizontal scan coils from the line stage.
\"You can\'t make a circuit fool-proof, cause fools are so ingenious!\" |
Oops! I meant horizontal line, sorry.
I also forgot to mention that banging on it (I know... ignorant man's first tool) used to fix it some of the time. Now that tool doesn't work so well. |
Ok then the previous advice you mentioned seems in order.
actually problem you describe is quite common. it is usually to be
traced to poor connection which might might be further eroded by arcing and that's why you cannot reproduce it. this also happens due thermal problems if chip overheats but in this case banging is unlikely to help. i suggest resoldering all connections on and around vertical osc. and cleaning contacts on the yoke connector. vertical osc/driver is usually single chip so it should be easy to replace. it might have gone by now after long strugle with arcing load. power for vertical circut is normally derived from coil/tap on the high voltage transformer used in the end stage of horizontal circuit. i've seen such problems (loose connection or cracked PCB) near the transformer. same suggestion as above - inspect for cracks, check continuity and resolder. make sure to give some time to capacitors to discharge before getting inside tv. if you get it to work even briefly - great, this is time to start some testing. normally in such case one would use cold spray to freeze parts of the circuit. cold makes things shrink so if the problem is not cured it will be easily found by applying directed jet of cold gas from the spray can. be careful since this can only yield results if performed on running equipment so don't go crazy, don't make spils, don't toch much etc. sometimes i had to use heatgun first to get to working condition before using freezing spray to pinpoint problem. again, all this thermal stress is not too good so use it carefuly, don't blow heat on heatsinks (should be obvious...). i would suggest hair dryer instead of real heatgun (much lower chance of damaging something). |
