Old 15th December 2004, 03:39 PM   (permalink)
Default Radio problem
hey.
I have a Sony cd\tuner. I have receiveing problems with some stations. on the tuner sections I saw 6 adjastable resisters or capacitors. does someone know what should I adjast to get a perfect receive station.
sorry for my english
thanks a head...
Zener_Diode is offline
Old 15th December 2004, 04:45 PM   (permalink)
What is the problem with the stations which you do not receive well?
Are they too weak, or too far away?
Are they being swamped by stronger local stations?
Are there two distant stations on the same frequency?
Whatever the problem is, I am 99.9% sure that it will not be fixed by blindly tweeking the internal adjustments in the radio.
A better antenna may be a solution to your problem.
JimB is online now
Old 15th December 2004, 05:22 PM   (permalink)
Exactly!!!
panic mode is offline
Old 15th December 2004, 06:32 PM   (permalink)
If you don't understand what you are doing you shouldn't adjust things!, particularly as they almost certainly won't have gone out of alignment on their own - it's more likely there's a fault instead (assuming it used to work well?).
Many years ago we had a guy bring a black and white dual standard TV in for repair, it was a valve set, and being dual standard had a huge amount of IF transformers on the chassis (pre-PCB). As he brought it in, he commented that he had "tightened all those loose screws down", an examination showed that he had taken every tuning core to the bottom!!.
Old 15th December 2004, 08:10 PM   (permalink)
I receive didm't receive stations like in a normal radio. and the station I receive doesn't appear on others tunners.
Old 16th December 2004, 06:10 PM   (permalink)
Listen to Nigel... those variable caps tune the Intermediate Frequency and discriminator oscillators-- changing those will render your reciever totally inoperable. The person who brought that TV in most likely walked right back out the door to purchase a replacement since returning all the oscillators would take forever without the custom rig they use at factory.
Dngrsone is offline
Old 17th December 2004, 04:12 AM   (permalink)
You are receiving stations outside the normal frequency range. The only problem that's happened to your radio is that its range of resonant frequencies has changed. This can happen if your radio becomes old or has suffered an impact.
The solution is that you should adjust your Coil at the front end. i.e. adjust the coil which is in parallel with your main tuning capacitor.
Do tell me if this works.
www.vaibhavbirit.bravehost.com
Vaibhav Birit is offline
