Old 14th December 2004, 02:50 AM   #1
Default unknown Vcc.....pls help :(
hi,i have a few questions about the schematic from the following website , http://home.att.net/~wzmicro/6203drv.html
1)what is the Vcc is needed since the "direction" and "motor on/off" also supply voltage...can it be ignore??
2)if it do need,what is the suitable voltage?
3)are the "direction" and "motor on/off" voltage should be as same as Vcc?
i like electronic but still newbies pls guide me....thanx a lot!
tcp is offline
Old 14th December 2004, 03:28 AM   #2
Whenever you don't know the voltage look at the ics' to see what they're rated for.. The circuit you show has a 5volt supply and a 24 volt supply..
The logic ,or control is 5v and the motor is 24..
You will need both to make this operate properly...
gerty
gerty is offline
Old 14th December 2004, 05:19 AM   #3
thats a good question. y dont u email them, theres an email adress @ the bottom of the page
zachtheterrible is offline
Old 14th December 2004, 06:32 AM   #4
poof
Your website has been blocked
Juglenaut is offline
Old 14th December 2004, 06:32 AM   #5
Use a solid state relay with Logic switching a 9-24DC volt source. A 5volt (logic) or a +24V coil relay will work to.
Old 14th December 2004, 01:46 PM   #6
74LS04 is TTL chip expecting input signals in range 0 to 5V.
Quick look in L6506 datasheet confirms that all inputs (including pins 6 and 4) have pretty much the same rating (0-3 normal with absolute maximum rating of 7V). R1 and R2 are pull-up resistors to Vcc so Vcc should be 5V.
panic mode is offline
Old 15th December 2004, 04:03 AM   #7
thanx for replying ,i'm assume that is a logic input so i will try to use 5volt as it Vcc and same with "direction" and "motor on/off"...hope this will work.....thanx again!
tcp is offline
unknown, vccpls
