i want to use non conventional energy source such as Wind energy to charge my Ni-Cad batteries.
Can anyone provide me with an elegant circuit with good explanation for doing the same
www.vaibhavbirit.bravehost.com |
If you can get the correct Shape of Propeller..
hooking it to a small dc motor should give you plenty of current to charge your NiCd batteries.. |
Actually It would help to know the voltage and amp hour rating for the batteries . As far as a propeller , use the fan blades from a window or bax fan. It's premade and el cheep-o
i found this on a website..i have just seen some Really cool generator blades ..
Thanks WilliB for the excellent pdf suggested. Also thankyou TillEulenspiegel for the info.
I will start building one...
How many batteries are we talking about in series that you want to charge?
Using a 540 DC motor or better bearing motors, best would be a brushless motor that is rectified. Motors must be ratio'ed to a gear box or driven directly by a large spur gear and a small pinion gear to be efficient the load form the motor must be as reduced as possible but allow adaquet current and free flowing of the empellers. Just remember that the energy produced by the generator must be higher than that of the unit being charged, other wise it will just be a fan. Most DC motors I play around with need to spin way to fast to be pratical for generators with wind to charge a 7.2 volt battery, individual cell is a different case. I made one out a box fan with a gear the matched to the hub with 4 DC motors, two series in parallel bank with the other two series and some other stuff to make it happen. I found that if closely matched motors work very good for this. This generator produced about 8 volts at 3 amps with a steady 25 Mph wind, it is also good as a DC fan.
Your website has been blocked |
did you know that the Savonius wind generators are stackable !!.. |
I can still remember many years ago, when I had some interest in this subject, reading about the "Darius eggbeater" and other turbines were fascinating stuff.
http://www.nrel.gov/data/pix/Jpegs/00182.jpg Quote:
(permalink) | ||
the pictures of the 'eggbeater' are awesome.!! and 500-kW is a lot of power.. |
these Savonius wind generators have a lot of torque , for their size..
the one in this pdf. http://www.re-energy.ca/pdf/cp1.pdf currently i have one attached to a small motor/generator.. mounted directly to the motor shaft. problem is it doesnt spin fast enough..i may have to gear it.. i am getting 1.1 Volts out of it .. when it is in front of a fan.. if i use gears i can increase the speed of the generator although this really complicates the design .. |
unfortunatly i have no experience with gears..
How should i do it?? i think i want the drive gear ( from the Savonius ) to drive a large gear then drive a gear smaller than the drive .?? does this sound right..??? |
If you want some decent gears, I got a bunch from All Electronics. http://www.allelectronics.com Go to 'gears' from the main menu, and 'SET OF 5 GEARS AND BUSHINGS'. 5 sets of the assorted gears or $10.00, and they come with adapters. Anybody making a bigger one of these, I saw a 'How it's Made' show on commercial wind generaters and they were using modified car alternators, which are more efficient then a generator. I would think you could get a smaller version out of a motorcycle or scooter for a smaller turbine. It would still have to be much larger than the project one shown in the PDF.
Mark Higgins |
Mark you're right i didnt use their design exactly..
below are pics of what i did.. this one is the Savonius wind collector part.. |
this one is a close up of how i connected the motor /generator to the Savonius wind collector..that plate (with the screw at either end) above the motor is galvanized sheet metal..what you cant see is the connection of the plate to the nylon pulley connected to the motor shaft..
i had to drill and tap two small screws to hold the plate .. |
