| thanks for the links .. I think that i am going to use one of my 5 1/4 hard drive spindle /motor assemblies for the lathe , i allready used it to fabricate the plexi glass , that and a dremmel , worked pretty well.. the nice thing about using the assembly is that you can bolt it down with three screws , the holes are allready there.. one of hard drive (assemblies) also had a linear slide which could be used as a tool holder with some modifications.. | |
| oops | |
| another update :: I just mounted ONE armature , and when i spin it fast , I get 4 Volts p-p !! .. from one armature !! that works out to 32 V single phase p-p ..Eight armatures at 4 V each.. i wonder if it will turn out that way.. i have the spindle mounted on a very flat board of mahagany and the armature mounted to the board .. the spacing between the magnets and the armatures is less than 0.010 of an inch , which i believe is critical to get maximum voltage .. | |
| that white paper between the base and everything else is a layout of where to put the armatures.. as you can see i am only using two pieces of threaded rod to mount the armatures that seems for now to be enough.. | |
| neat waveform huh ? this is from one armature and two magnets , and a light spin . and 1 V/ Div its amazing how This turns into a sinusoidal wave with evenly spaced magnets and armatures.. the first negetive going pulse is when the armature encounters the first magnet.. the positive spike is when the armature encounters both magnets .. the second negetive going pulse is when the second magnet leaves the armature.. when you spin it the other way the waveform is inverted. | |
| These are some pics of today. | |
| More pics.. The dial indicator came in handy to level out the height of the arms. But still the one in the back is touching a little bit , GRRRRR .. | |
| Ok i'm getting at least 30 V p-p no load . the wave looks similiar to the one above .. just bigger.. hmmm , not really sinusoidal .. i had a nice sine wave before.. oh well .. :roll: late last night i put the sanonius wind turbine on top of the permenent magnet generator .. and discovered ..I need a BIGGER wind collector..lol my 2 gal bucket isnt cuttin it.. the reason is , when i put a load on the generator it slows down too much on the bright side i was able to light a mini mag light bulb with wind power from a fan .. :!: i hooked it up right to the raw output of the generator it was really cool the way it was frickering .. | |
| Got some data here Spinning the generator by hand ( with a pen stuck in one of the holes ) and four 1N 4001 diodes in a bridge rectifer setup.. with no load V = 13-14 V.. with 12 ohms load V= 1.23 v , A = 0.24 A with 3.3 ohms load V= 0.62v , A = 0.36 A with 1.3 ohms load V= 0.37v , A = 0.502 A ( just the meter) spinning it as fast as i could with just the meter i got 0.6 A .. | |
| I think i am finally able to answer the origional question.. Yes .. the generator will indeed charge Rechargeable Batteries ( with not too much effort either !! just hooked two NiMH batteries in series , and as soon as it started turning it started charging them.. Rest voltage on the two batteries = 2.61 V i was able to get the voltage up to 2.82 V @ 200 mA .. so yes it can be done..just need a larger wind turbine. | |
| Well done, Nice work, now just do some thinking into how it will spin by natural wind. That will be marvellous.
__________________ www.vaibhavbirit.bravehost.com | |
| Vaibhav glad to see you .. i thought at first that you got hit by the tsunami but after looking at map i saw that you were on the west coast.... i believe that it WILL charge , by natural wind , because as soon as it started spinning , it started charging ..so even at very slow speed it will charge.. ..maybe you (or i ) would be better off with the propeller type .. although i really dont have the room for a 8 to 10 foot dia. propeller blade.. | |
| things that i would like to try next .. 1) make the armatures smaller , i origionally designed them for the much larger Home Depot Magnets .. i figure a little bit thinner , and not as wide , about as wide as the magnets 1/2 " would be better.. and i can shave 1/2 " off the length.. this will give me more area for the flux to cut through.. also i found a chunk of laminate that i can use to check to see if it would work better than no laminate.. 2) although the saw blade works very well it unfortunatly does flex a little bit , a few thousandths of an inch , if the 10" diameter one is thicker that would be a better choice.. | |
| i found this interresting concept, while looking around .. http://www.speakerfactory.net/wind.htm http://www.speakerfactory.net/wind954c.jpg Doug produces these in much larger versions up to 6 KW , Wow !! This caption is under the picture. "The car headlight at Doug's feet is 50 watts The rotor size is only fourteen inches! Wind speed in the 20's mph (more rotors produce more power)" | |
| The 5 gallon bucket i tried actually works :lol: .. It is charging two 1.2 V NiMH Batteries at this moment.. I have also been experimenting with a savonius shroud which funnels the incomming wind into the cup part of the collector and blocks the wind from the convex part of the collector.. | |
