| ok after i put just two magnets on a strip of steel.. and passed them over "just one" of the thinner wire armatures .. i got 2V peak to peak !!!! that is amazing !! imagine how much voltage i could get with a magnet on either side of the coil.. like the double rotors of earlier discussion.. that is , an armature set , sandwiched between two rotors with magnets attracting each other.. | |
| this is my current test fixture.. i need a lathe damnit! lol the smaller silvery magnets are much more powerful than the larger magnets.. With the eight home depot magnets still in place and the eight new Neodymium magnets i just got 10V p-p | |
| i am pondering the idea of putting some iron core/ laminates in the center each winding , anyone have any thoughts . would it be a good or bad idea ? and why ? would it be a waste of time or could i get more voltage out of it if i used laminates or would they just interfere with the simplicity of the generator ? | |
| Eh WilliB, I'm sure on windstuffnow you can but 10" disc's off them cheap about 10 bucks I think. I'm sure Ed could supply you with a disc you need just take a look. Cheers Bryan1 | |
| i'm at the point in the design stage where i need more info.. i need to know how much torque the savonios wind generator can produce .. i am thinking of one the size of a 5 gal bucket.. i need to know if a 3 to 2 gear ratio is to much or if a 1 to 1 is best.. i found a source for sprockets and chains.. https://sdp-si.com/eStore/Direct.asp?CP=Index.htm i am going to use a chain because 1) low losses involved in transferring power 2) so i dont have to connect the savonius wind generator directly to the top of the rotor.. just thinking out loud so to speak.. | |
| i found a 8 inch plywood saw blade at home depot to use for the rotor ( just gotta grind off the teeth..) $6.95 and i found a 2 gal bucket for the savonius part at the dollar store.. | |
| another update on the output of the Permenant Magnet Generator project :: i am now getting 15 V p-p with 7 armatures and 16 mannets spaced as above .. the plan is to use 8 armatures .. Each armature has a resistance of about 0.9 to 1.0 ohms.. the sine wave is sweet , BTW .. the faster it goes the more voltage you get from it.. This is all spinning the rotor by hand , somewhere around 150 RPMs .. | |
| am i talking to myself here ? anyway the first pic is the new rotor built on an 8 inch saw blade.. with the http://www.windstuffnow.com/ magnets mounted sort of where they will end up.. the second pic is the savonius wind generator part with a cd on top for size reference..it is built with a 2 gal bucket i have another disk like the base to put on top courtesy of home depot , it came from a used spool from the electrical wire section .. as for bearings , i have two that i can use , i am going to ues fiberglass resin to secure them in place.. | |
| Oh well too much mass to react fast enough to a gust of wind.. i'm thinking 1/8" plexyglass would work much better.. | |
| Plexi-glass works much better.. it turns with the air from two 12V pc fans.. | |
| EDIT : just the savonius part turns with the wind from the pc fans i havnt hooked the generator to it yet i think that i will put the generater underneath after all.. | |
| I havnt mentioned it yet but i plan on using a PIC controller to monitor the rotation speed of the generator and compare it to an Anemometer.. If the generator slows down compared to the speed of the wind meter then i could disconnect the load till it speeds up again.. | |
You can make a lathe from a hand drill, but I cannot find the link just yet. ********* found a One for a CNC machine http://www.pathcom.com/~vhchan/cnc/cnc.html foam lathe http://www.dansworkshop.com/Hot%20wi...0cutting.shtml | ||
