Old 12th March 2005, 01:39 PM   (permalink)
Default Re: re: motors
Originally Posted by peterpan
Go with the steper motors from old printers and computer controlled machines as they make power at low rpm and it's alot easier than building your own alt for the mini gennies, try using a R/C aeroplane propeller adaptor to connect the prop to the motor shaft, use diodes to convert to dc power and wallah it works!
But he's having so much fun :lol:
The thread has now stretched to 11 pages, and he keeps us all interested with his exploits - introducing common sense will only spoil the enjoyment!.
Old 12th March 2005, 03:17 PM   (permalink)
Default savonious
while ago I made a savonious from pvc piping that gave a different perspective to savonious being slow and torquey, made from 90mm down pipe and about 4m tall the thing spun super fast but I never hooked a gen or a tach to get any readings very cheap to make and good for a place where a hawt are frowned upon by the communuty, when spinning looks abit like a pole.
Three of these in a triangle support at the top and bottom may hold itself up and might not need a frame, ie each one supports the other.
Could be a new kind of art form eh??
peterpan is offline
Old 12th March 2005, 10:36 PM   (permalink)
this is the rotor from the abandoned motor project..
the magnets are supported by the lamenates from the old armature.
i origionally had just four magnets this picture has 12 , six doubled up, for more magnetic flux....
if they look like they tilt twards the inside , on the left , they do.. I was trying to make more room for the coils..
i am in the process of making an armature winder of sorts..
peterpan, i am very interrested in your savonious would it be possible to post a picture of it ? , or at least a diagram?
williB is offline
Old 17th March 2005, 02:56 PM   (permalink)
Default super savonious
Taller rather than wider.
peterpan is offline
Old 17th March 2005, 03:03 PM   (permalink)
no picture huh? oh well..
williB is offline
Old 17th March 2005, 04:18 PM   (permalink)
Remember the tuna head anomemeter from a while back..well i am going to use that, ( slightly differently ) and using peterpans idea of the three bladed savonious.. it should be awesome !! so instead of just three tuna heads , i am going to try nine , to start with..three stacked ,one above the other..connected on Aluminum strips , anchored to a six inch disk on the top and bottom , with a 1/4 20 threaded rod going down the center, all this will be placed on my first generator,the one with the 8 inch saw blade for the rotor..i may or may not need a bearing on the top, we will see..
the armature winder needs work.. more on that later..
williB is offline
Old 18th March 2005, 11:12 AM   (permalink)
Default savonious
I may have confused people with the description the three thingy, I do not mean the mill had three blades although I belive three blades are better than only using two, I was refering to the extravagant framework some people have used hold the top bearing. Usually there are two or three upright poles around the outside connected by a crossbar at the top which holds the bearing to stabilise the central rod of the mill, I 'm thinking we may be able to substitute the frame for other mills, say three in a triangle formation??.
peterpan is offline
Old 20th March 2005, 04:27 AM   (permalink)
well it wasnt awesome..lol
i suppose i should have stuck with the propellers..the tuna heads didnt come close to the props in speed..240 Vs. 526 RPM .. no contest ...oh well .. i had to try ..
williB is offline
Old 21st March 2005, 03:16 PM   (permalink)
it worked , but it didnt have the torque , or the speed , to turn the generator , as well as the propellers do..probably because the propellers dont have the negetive effect of having to push the opposing heads around to catch the wind..which i suppose is the problem of all savonius types...
looks kind of rube goldbergish dosent it..lol
williB is offline
Old 22nd March 2005, 01:05 AM   (permalink)
l
The bigger problem with savonius type windmills is that they simply do not have the same swept area of a comparable size propellor facing the wind. Hence they cannot extract anywhere near the energy.
With a propellor its the swept circle area minus a small part for the hub that gets energy from the wind.
With savonius types its only 1/2 the swept rectangular area.
Some egg beater canting blade designs might be more efficient than the simple savonius at the expense of complexity.
The downside of propellor type windmills is that they need a tail to face them in the right direction unless the prop is designed to face downwind.
In the latter case the wind shadow from the supporting mast plays a role ( the blades might make more noise from the unloading in the shadow).
Keep at it fellows and have fun
Klaus
Klaus is offline
Old 23rd March 2005, 01:09 PM   (permalink)
Default pvc savonius
:lol:
peterpan is offline
Old 23rd March 2005, 01:36 PM   (permalink)
and that worked ??
williB is offline
Old 23rd March 2005, 06:52 PM   (permalink)
i just had another milestone ..
i was able to light a tail light by wind power alone..
i did not know that the camera could stop action like that , that fan is on high !!
i have 22 magnets on the rotor, about 1/2 '' apart. and i was getting 20 V no load from four armatures..
after about ten seconds it slows down too much to keep the bulb lit..but hey, with more wind ( than a fan) it might keep going..
EDIT:: both filiments of the bulb are not lit ,just the one with the skinnier wire . must be the camera.. :roll:
williB is offline
Old 24th March 2005, 04:50 AM   (permalink)
williB, did you read about this: http://www.otherpower.com/cgi-bin/we...mes;read=17023
? it may help getting you even more power from your wonderful device
:wink:
Klaus
P.S. interesting how the camera also showed that your once nicely staggered propellors are no longer nicely staggered
Klaus is offline
Old 24th March 2005, 05:56 AM   (permalink)
yeah i learned a lot from that site ..and i have been thinking about how i could use two rotors .. in my set up i would have to support the generator by the armatures which would be sandwiched between the rotors..its not out of the question , just a little more difficult..
as for the propellers , whose idea i got from Doug Selsam ( see bottom of page six of this thread ) when they slip ,they tend to follow in the slip stream of the one in front of them , like the middle one did,.. ideally there should be more space between them..
williB is offline
