Old 13th December 2004, 12:05 AM   (permalink)
Default Current consumption meter
Does anyone know if there is a bench or handheld meter that can log current consumption down to uA or even nA level and over period of days?
Steve
Scarr is offline
Old 13th December 2004, 12:33 AM   (permalink)
Do you want to sample (and log) current at regular intervals or do you want to know how much energy was consumed over a period (day/s) due to current consumption?
Maxim have a Coulomb counter that I have used before. The only problem is that it can't follow sharp transients.
http://www.maxim-ic.com/appnotes.cfm...te_number/2096
Another from Linear
http://www.linear.com.cn/prod/datash...datasheet=1020
TheOne is offline
Old 13th December 2004, 01:07 AM   (permalink)
I built one. It depends a lot on how much current capacity you need and how much accuracy you need, so it's hard to build one without knowing the app.
Oznog is offline
Old 13th December 2004, 09:31 AM   (permalink)
Can't handle sharp transients? Stick a big capacitor across it it then!
spuffock is offline
Old 13th December 2004, 09:38 AM   (permalink)
He didn't say "can't handle", but "can't follow" - adding a big capacitor would make it far worse at doing that!.
Nigel Goodwin is online now
Old 13th December 2004, 06:39 PM   (permalink)
Default Reply
I want to log the total power consumed, so if I placed a load of 1mA for 1 hour then increased it to 500mA for 1 hours result shows 501mAh
There will be long period of 1mA followed by several sharp rises to 500ma and greater, I just want to stick a meter in-line and get a total reaing with a log ideally. even better if I can connect a PC.
Not looking for a home made project but a of the shelf product.
Thx
Scarr is offline
Old 13th December 2004, 08:04 PM   (permalink)
In our case we were asked to design something as the company could not find anything (off the shelf) on the market to do that. The problem with their application was the existence of a low level random floor current (you can say almost a noise current) of about 1 - 10uAp-p with sharp current pulses every now and then of up to 30mA - 20uS wide. They were trying to determine how long this apparatus would work on its internal long life battery 3v lithium without running it for a year to find out. It was for a remote metering application with no mains supply or the possibility to use solar power.
At the end we designed a device that was very accurate with less than 0.5% error calculated over a week. We could not use the Maxim or Linear chips.
TheOne is offline
Old 14th December 2004, 08:49 AM   (permalink)
Default Reply to TheOne
Hi "TheOne"
It sound like thats what we are looking for but with a pulse of up to 2amp and only as low as 1uA, is your device a finished product I can buy?
SCarr
Scarr is offline
Old 14th December 2004, 03:12 PM   (permalink)
Would like to help you out, but all rights were sold to this company in the UK (I am in the US). As far as I know they implemented this module as part of a test sets they produce for their product.
Maybe Oznog can help you out on this one.
TheOne is offline
Old 15th December 2004, 01:39 AM   (permalink)
Take a look at:
http://www.allegromicro.com/hall/currentsensor.asp
Kent
kentken is offline
Old 15th December 2004, 07:20 PM   (permalink)
I've made one of these, it's still about somewhere. On the most sensitive range it measures 0.1 microcoulomb per step. It still has its original batteries after seven years, and there's no power switch. The only trouble is that it doesn't have a pretty custom made box. That's what stops useful things being made. No pretty boxes at affordable prices.
Incidentally, a big capacitor across its terminals will integrate spikes that the device would otherwise clip.
spuffock is offline
Old 15th December 2004, 07:31 PM   (permalink)
On our design the customer didn't want any range selection, which left us with the problem how to deal with the massive dynamic range, short peak transients and still maintain less than 1% error.
TheOne is offline
Old 15th December 2004, 07:49 PM   (permalink)
I wouldn't mind the job of designing the guts of one to a reasonable specification. I certainly took no great pains to build the one I have, and it proved quite up to the job it was made for, estimating the battery life of a weather station datalogger. However, commercial requirements, like a pretty box and the circuitry built from pure Chinese cheapening, preclude the manufacture of it.
spuffock is offline
