| Hello! I have a 91mm fan "9232-12HBTL" made by Datech. It has a sensor output. My question is: how do I use it? How's the information outputted? Pulses? Voltage? Thank you. | |
| typicall it is a ttl level 0-5V square wave that is usually either 2 or four pulses per revolution. It is a pretty easy signal to deal with as it can be read by most general purpose microcontrollers. kingpin094 | |
| it is probably a hall effect switch .. like the one in this post http://www.electro-tech-online.com/v...ght=hall#64651 hope that helps.. | |
| I commented about one of these at some point (but I cant find the post). The few that I have are all open collector outputs. So you must use a pull-up resistor on the sensor output. Mine did have hall effect sensors inside them. | |
